Hey guys,
Since me and some coworkers had very bad experiences with the provider supplied router/modems we've bought 5 mikrotik RB2011UiAS-2Hnd devices.
But we cant get good troughput with wireless networks the speed we are getting fluctuate a LOT i've seen 80Mbps once on www.speedtest.net but must of the time it fluctuates between 5Mbps and 15Mbps
On a wired connected i'm reaching the full 180Mbps download speed. To be honoust we've been trying a lot and we are clueless where we should look and what we are doing wrong. The config of my wireless interfaces is as follows
[admin@MikroTik] /interface wireless> print detail
0 R name="wlan1" mtu=1500 mac-address=4C:5E:0C:2C:2F:CF arp=enabled
interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroSaga" frequency=2437
band=2ghz-onlyn channel-width=20/40mhz-eC scan-list=default wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=Private Network compression=no
[admin@MikroTik] /interface wireless> monitor wlan1
status: running-ap
channel: 2437/20-eC/gn
wireless-protocol: 802.11
noise-floor: -95dBm
overall-tx-ccq: 89%
registered-clients: 1
authenticated-clients: 1
wmm-enabled: yes
current-tx-powers: 1Mbps:27(27/30),2Mbps:27(27/30),5.5Mbps:27(27/30),11Mbps:27(27/30),
6Mbps:27(27/30),9Mbps:27(27/30),12Mbps:27(27/30),18Mbps:27(27/30),
24Mbps:27(27/30),36Mbps:26(26/29),48Mbps:25(25/28),54Mbps:24(24/27),
HT20-0:27(27/30),HT20-1:27(27/30),HT20-2:27(27/30),HT20-3:27(27/30),
HT20-4:27(27/30),HT20-5:27(27/30),HT20-6:25(25/28),HT20-7:22(22/25),
HT40-0:27(27/30),HT40-1:27(27/30),HT40-2:27(27/30),HT40-3:27(27/30),
HT40-4:27(27/30),HT40-5:27(27/30),HT40-6:25(25/28),HT40-7:22(22/25)
notify-external-fdb: no
[admin@MikroTik] /interface wireless> /interface print
NAME TYPE MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1-gateway ether 1500 1598 4074 4C:5E:0C:2C:2F:C5
1 S ether2 ether 1500 1598 4074 4C:5E:0C:2C:2F:C6
2 S ether3 ether 1500 1598 4074 4C:5E:0C:2C:2F:C7
3 S ether4 ether 1500 1598 4074 4C:5E:0C:2C:2F:C8
4 S ether5 ether 1500 1598 4074 4C:5E:0C:2C:2F:C9
5 S ether6-master-local ether 1500 1598 2028 4C:5E:0C:2C:2F:CA
6 S ether7-slave-local ether 1500 1598 2028 4C:5E:0C:2C:2F:CB
7 S ether8-slave-local ether 1500 1598 2028 4C:5E:0C:2C:2F:CC
8 S ether9-slave-local ether 1500 1598 2028 4C:5E:0C:2C:2F:CD
9 S ether10-slave-local ether 1500 1598 2028 4C:5E:0C:2C:2F:CE
10 sfp1-gateway ether 1500 1598 4074 4C:5E:0C:2C:2F:C4
11 RS wlan1 wlan 1500 1600 4C:5E:0C:2C:2F:CF
12 R bridge-local bridge 1500 1598 4C:5E:0C:2C:2F:C6
