Hi guys,
I do a service scan on Mikrotik routerboard with a software (GFI Lan Guard) and it find POP3, SMTP, IMAP4 service enable on routerboard: why?
I check under IP/service of routeros but I don’t find any smtp,pop3 or imap4 service.
Also with Dude if i try to check a routerboard it find smtp,pop3 and imap4 service; if i try to connect via telnet (telnet ip address 110) I can’t, so i think service isn’t available: is it correct?
you have to configure the firewall, so that it blocks such requests. put firewall rules in the input chain, that block everything coming from unknown addresses, and also block access to unused ports. just make sure that you allow things like DNS requests for the router.
I use routerboard in bridging mode in a point-to-point wireless link and so I wouldn’t use firewall rules.
Why does Dude software find pop3, smtp and IMAP4 service active in routerboards? Is it possible to disable this services?
quite a while here … BUT … i ran into the same curiosity …
despite i have a fw-rule which blocks all ports for the INPUT chain on the gateway interface, nmap shows open ports which have NEVER been opened, used, forwarded etc.
nmap -sT -sU -T4 -v -v -F -Pn [my host’s wan ip from ISP]
Starting Nmap 7.01 ( https://nmap.org ) at 2016-02-09 17:27 CET
Initiating Parallel DNS resolution of 1 host. at 17:27
Completed Parallel DNS resolution of 1 host. at 17:27, 0.00s elapsed
Initiating UDP Scan at 17:27
Scanning home.[myDomainName].at (178.xxx.xx.xxx) [100 ports]
Completed UDP Scan at 17:27, 11.13s elapsed (100 total ports)
Initiating Connect Scan at 17:27
Discovered open port 995/tcp on 178.xxx.xx.xxx
Discovered open port 993/tcp on 178.xxx.xx.xxx
Discovered open port 443/tcp on 178.xxx.xx.xxx
Discovered open port 80/tcp on 178.xxx.xx.xxx
Discovered open port 110/tcp on 178.xxx.xx.xxx
Discovered open port 143/tcp on 178.xxx.xx.xxx
Discovered open port 22/tcp on 178.xxx.xx.xxx
Completed Connect Scan at 17:27, 2.36s elapsed (100 total ports)
Nmap scan report for home.[myDomainName].at (178.xxx.xx.xxx)
Host is up, received user-set (0.022s latency).
rDNS record for 178.xxx.xx.xxx: 178.xxx.xx.xxx.wireless.dyn.drei.com
Scanned at 2016-02-09 17:27:03 CET for 13s
Not shown: 100 open|filtered ports, 93 filtered ports
Reason: 193 no-responses
PORT STATE SERVICE REASON
22/tcp open ssh syn-ack
80/tcp open http syn-ack
110/tcp open pop3 syn-ack
143/tcp open imap syn-ack
443/tcp open https syn-ack
993/tcp open imaps syn-ack
995/tcp open pop3s syn-ack
Read data files from: /usr/local/bin/../share/nmap
Nmap done: 1 IP address (1 host up) scanned in 14.33 seconds
Raw packets sent: 200 (7.156KB) | Rcvd: 36 (5.102KB)
and here is my firewall setup:
Address Lists (some permanently blocked “china-nets” are not pasted)
[spippan@Cerberus] /ip firewall address-list> print where !dynamic
Flags: X - disabled, D - dynamic
# LIST ADDRESS TIMEOUT
13 ;;; LAN sp-private
whitelist 192.168.1.0/24
14 ;;; VPN net Cerberus
whitelist 10.20.30.0/24
17 ;;; daniLAN
whitelist 192.168.3.0/24
18 X whitelist 62.218.xxx.xxx/31
21 ;;; VPN net sp-private
whitelist 10.20.31.0/24
