Port 123 Blocked - any workaround?
Hello!
My ISP is filtering all traffic through port 123 and I cannot automatically sync the date and time of my RouterBoard.
It is very annoying…
Can you give me an idea for a workaround (if such actually exists…)
Thanks!
Only two solutions are an external server that uses a different port or turn a PC into an NTP Server locally
Thank you for the reply.
But how can I set up the SNTP client to connect at different port in unicast mode?
Sorry for the delayed response on this.
You use NAT along with DST NAT to change the DST Port.
Thanks for your reply.
I’ll try this when i have a little free time and I’ll post back the results.
