Did a remote port scan and it says port 53 is open. I’m confused by that as I don’t have anything in the IP>Firewall section for port 53.
I do have some things in the IP>NAT section for port 53, but I thought that was all facing internal. Clearly I’ve misunderstood.
[admin@gateway] > ip/firewall/nat/ print
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
1 ;;; DNS Redirect UDP
chain=dstnat action=dst-nat to-addresses=10.1.0.2 to-ports=53 protocol=udp src-address=!10.1.0.2/31 dst-port=53
log=no log-prefix=""
2 ;;; Rewrite DNS lookups UDP
chain=srcnat action=masquerade to-ports=53 protocol=udp dst-address=10.1.0.2 dst-port=53 log=no log-prefix=""
3 ;;; DNS Redirect TCP
chain=dstnat action=dst-nat to-addresses=10.1.0.2 to-ports=53 protocol=tcp src-address=!10.1.0.2/31 dst-port=53
4 ;;; Rewrite DNS lookups TCP
chain=srcnat action=masquerade to-ports=53 protocol=tcp dst-address=10.1.0.2 dst-port=53 log=no log-prefix=""
Not sure why any of these rules would be responding externally. Please help me understand.
anav
May 18, 2025, 7:45pm
2
Please post full config
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys )
Here you go. Thanks for looking.
# 2025-05-18 14:10:45 by RouterOS 7.18.2
# software id = MH6J-YZ08
# model = E50UG
# serial number = 12345678900
add admin-mac=F4:1E:57:XX:XX:XX auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.1.0.200-10.1.0.230
add address-pool=dhcp disabled=yes interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
set discover-interface-list=none
/interface ovpn-server server
add mac-address=FE:1F:09:XX:XX:XX name=ovpn-server1
add address=10.1.0.1/24 comment=defconf interface=bridge network=10.1.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add address=10.1.0.0/24 comment=defconf dns-server=10.1.0.2 gateway=10.1.0.1
/ip dns static
add address=10.1.0.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment="DNS Redirect UDP" dst-port=53 \
protocol=udp src-address=!10.1.0.2/31 to-addresses=10.1.0.2 to-ports=53
add action=masquerade chain=srcnat comment="Rewrite DNS lookups UDP" \
dst-address=10.1.0.2 dst-port=53 protocol=udp to-ports=53
add action=dst-nat chain=dstnat comment="DNS Redirect TCP" dst-port=53 \
protocol=tcp src-address=!10.1.0.2/31 to-addresses=10.1.0.2 to-ports=53
add action=masquerade chain=srcnat comment=" Rewrite DNS lookups TCP" \
dst-address=10.1.0.2 dst-port=53 protocol=tcp to-ports=53
/ip ssh
set host-key-type=ed25519 strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Denver
/system identity
set name=gateway
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.1.0.3
add address=10.1.0.18
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
Anav probably wanted to see the full configuration because there could’ve been a firewall rule or something else that could’ve been a security issue but even from the NAT snippet one could draw a conclusion what the reason is:
This rule redirects any packet with destination port 53, regardless whether it’s from WAN or LAN, to 10.1.0.2, with the exception of itself. So technically the aforemetioned port is open to the whole wide web and that could be easily fixed with adding a parameter in-interface-list=LAN
Ok that makes sense now. Yes changing it to in-interface-list=LAN does no longer show up from an external scan. Thanks!
anav
May 19, 2025, 3:27pm
6
That is correct, I do not even look at snippets LOL, good pickup by cat.
