port access
how to make simple things:
cisco
interface vlan3
ip address 10.10.13.1 255.255.255.0
interface GigabitEthernet1 / a
switchport access vlan 3
switchport mode access
I do not need a trunk
hi
you can add vlan interface in interfaces,for acceess gigabitethernet in vlan,you can set interface vlan in your interface that need.
in the ip address , you can set ip in your vlan interface.
sample:
[admin@MikroTik] /interface vlan> add name=VLAN2 vlan-id=2 interface=ether1 disabled=no
[admin@MikroTik] /interface vlan> print
Flags: X - disabled, R - running, S - slave
NAME MTU ARP VLAN-ID INTERFACE
0 R VLAN2 1500 enabled 2 ether1
for more help follow : http://wiki.mikrotik.com/wiki/Manual:Interface/VLAN
No, I do not work.
I gave up the idea of ​​using mikrotik in the network core.
They will stand only for the lengthening of some links (SXT-5D or SEXTANT)
