Hi All,
I have followed manual: https://wiki.mikrotik.com/wiki/Manual:CRS1xx/2xx_series_switches_examples + few other manuals and finally I came up with port based vlan configuration.
Here is how my network looks like: https://drive.google.com/file/d/1ZYr5Vk1iMwfOT4Dxdww8OLPNUD_dup1y/view?usp=sharing
Summary:
- Thee vlans are configured: vlan59, 69 and 79.
- Almost all physical ports belong to 10.69.0.x/24 subnet (vlan 69)
- All Access Points are supposed to be part of 10.69.0.x/24 subnet
- APs broadcast 3 different subnets (corresponding to vlans)
Almost everything works are expected. All wired devices receive IP address, the same story with all wireless clients. Surprisingly, that happens even though AP do not get IP addresses? How do I know: - No entries in ARP table;
- No leaseon DHCP;
- Access Points are grayed out in Controller (typical for issues on layer3 → lack of IP).
Can someone explain to me how the hell APs are able to transmit DHCP requests properly without having IP address assgined?
Here is my config:
# MikroTik RouterOS 6.46.4 (c) 1999-2020 http://www.mikrotik.com/
# mar/30/2020 21:33:22 by RouterOS 6.46.4
# model = CRS125-24G-1S
add name=my-bridge
set [ find default-name=ether1 ] comment="WAN"
set [ find default-name=ether2 ] comment="[A_SL_01]"
set [ find default-name=ether3 ] comment="[A_SL_02]"
set [ find default-name=ether4 ] comment="[A_SL_03]"
set [ find default-name=ether5 ] comment="[A_SL_04]"
set [ find default-name=ether6 ] comment="[A_SL_05]"
set [ find default-name=ether7 ] comment="[A_SL_06]"
set [ find default-name=ether8 ] comment="[A_KT_01]"
set [ find default-name=ether9 ] comment="[A_PR_01]"
set [ find default-name=ether10 ] comment="[B_GB_01]"
set [ find default-name=ether11 ] comment="[B_GB_02]"
set [ find default-name=ether12 ] comment="[B_GB_03]"
set [ find default-name=ether13 ] comment="[B_GB_04]"
set [ find default-name=ether14 ] comment="[B_GB_05]"
set [ find default-name=ether15 ] comment="[B_GB_06]"
set [ find default-name=ether16 ] comment="[B_GB_07]"
set [ find default-name=ether17 ] comment="[B_GB_08]"
set [ find default-name=ether18 ] comment="[B_DL_01]"
set [ find default-name=ether19 ] comment="[B_DL_02]"
set [ find default-name=ether20 ] comment="[B_DP_01]"
set [ find default-name=ether21 ] comment="[B_DP_02]"
set [ find default-name=ether22 ] comment="[B_GO_01]"
set [ find default-name=ether23 ] comment="[B_GS_01]"
set [ find default-name=ether24 ] comment=Plug&Go
set [ find default-name=sfp1 ] comment=Fiber disabled=yes
/interface vlan
add interface=my-bridge name=vlan59 vlan-id=59
add interface=my-bridge name=vlan69 vlan-id=69
add interface=my-bridge name=vlan79 vlan-id=79
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="ether2,ether3,ether\
4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14\
,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23"
add name=mgmt ranges=10.100.0.2
add name=pool-vlan59 ranges=10.59.0.2-10.59.0.254
add name=pool-vlan69 ranges=10.69.0.2-10.69.0.254
add name=pool-vlan79 ranges=10.79.0.2-10.79.0.254
add address-pool=mgmt disabled=no interface=ether15 lease-time=30m name=dhcp
add address-pool=pool-vlan59 disabled=no interface=vlan59 name=dhcp-vlan59
add address-pool=pool-vlan69 disabled=no interface=vlan69 lease-time=23h59m59s \
name=dhcp-vlan69
add address-pool=pool-vlan79 disabled=no interface=vlan79 lease-time=10h name=\
dhcp-vlan79
add bridge=my-bridge interface=ether2
add bridge=my-bridge interface=ether3
add bridge=my-bridge interface=ether4
add bridge=my-bridge interface=ether5
add bridge=my-bridge interface=ether6
add bridge=my-bridge interface=ether7
add bridge=my-bridge interface=ether8
add bridge=my-bridge interface=ether9
add bridge=my-bridge interface=ether10
add bridge=my-bridge interface=ether11
add bridge=my-bridge interface=ether12
add bridge=my-bridge interface=ether13
add bridge=my-bridge interface=ether14
add bridge=my-bridge interface=ether16
add bridge=my-bridge interface=ether17
add bridge=my-bridge interface=ether18
add bridge=my-bridge interface=ether19
add bridge=my-bridge interface=ether20
add bridge=my-bridge interface=ether21
add bridge=my-bridge interface=ether22
add bridge=my-bridge interface=ether23
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether7,ether22,ether23,switch1-cpu vlan-id=59
add tagged-ports=ether7,ether22,ether23,switch1-cpu vlan-id=69
add tagged-ports=ether7,ether22,ether23,switch1-cpu vlan-id=79
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=69 ports=ether2
add customer-vid=0 new-customer-vid=69 ports=ether3
add customer-vid=0 new-customer-vid=69 ports=ether4
add customer-vid=0 new-customer-vid=69 ports=ether5
add customer-vid=0 new-customer-vid=69 ports=ether6
add customer-vid=0 new-customer-vid=69 ports=ether8
add customer-vid=0 new-customer-vid=69 ports=ether9
add customer-vid=0 new-customer-vid=69 ports=ether10
add customer-vid=0 new-customer-vid=69 ports=ether11
add customer-vid=0 new-customer-vid=69 ports=ether12
add customer-vid=0 new-customer-vid=79 ports=ether13
add customer-vid=0 new-customer-vid=69 ports=ether14
add customer-vid=0 new-customer-vid=69 ports=ether16
add customer-vid=0 new-customer-vid=69 ports=ether17
add customer-vid=0 new-customer-vid=69 ports=ether18
add customer-vid=0 new-customer-vid=69 ports=ether19
add customer-vid=0 new-customer-vid=69 ports=ether20
add customer-vid=0 new-customer-vid=69 ports=ether21
add ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether\
11,ether12,ether14,ether16,ether17,ether18,ether19,ether20,ether21,ether22,e\
ther23,switch1-cpu" vlan-id=69
add ports=ether7,ether13,ether22,ether23,switch1-cpu vlan-id=79
add ports=ether7,ether22,ether23,switch1-cpu vlan-id=59
add address=10.100.0.1/30 interface=ether15 network=10.100.0.0
add address=10.59.0.1/24 interface=vlan59 network=10.59.0.0
add address=10.69.0.1/24 interface=vlan69 network=10.69.0.0
add address=10.79.0.1/24 interface=vlan79 network=10.79.0.0
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
--- [i]many entries here[/i] ---
set allow-remote-requests=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=xyz
/system clock
set time-zone-name=Europe/Warsaw
