/port baud rate per channel?
Hi!
I’ve got a RB922UAGS-5HPacD which has one USB port, and I’ve got two devices with serial ports that I need to access remotely via the RB922. If I add a 2x RS-232 ↔ USB adapter (FT2232) it appears in /port as one device with two channels. Is it possible to set the baud rate for each channel individually?
Thanks,
Hendrik
Did you ever get an answer to this ?
