RB750Gr3
6.39.3
today I found port flapping:
I guess that is a question and you’re asking for a reason ![]()
What device is at the other end?
Is the cable OK?
Does the remote end have power saving functions enabled?
Does the behavior cease when you disable auto negotiation on both ends?
-Chris
