I have an RB2011 what is working properly and actually 2 days ago I bought an L009UiGS to replace the predecessor.
The environment
Suppose that, I have internet on ether1 port w/ 89.89.89.89 IP. My internet service provider allowed to me only to open the 12443 port. I have started to use the router w/ default settings. So there is not special except this.
I have a web server on 10.0.1.2, obviously it binds on 443 port. I would like to forward the requests from 89.89.89.89:12443 to 10.0.1.2:443.
My settings
The setting should be so simple. dstnat rule to forward it to the server. Actually I tried at least 50 settings from internet, included w/ and my ideas and the docs: https://help.mikrotik.com/docs/display/RKB/Port+forwarding.
This is my simplest - almost - working solution:
add action=dst-nat chain=dstnat comment="443 forward - Fig.0" dst-address-list=WAN dst-port=12443 protocol=tcp to-addresses=10.0.1.2 to-ports=443
W/ this rule, I should see my web server from outside the network, sadly I cannot! BUT if I add another rule what is for - as I know - for hairpin (to see my website inside the network)
add action=masquerade chain=srcnat dst-port=443 protocol=tcp
So, if I add these rules, after that I can see my website inside the network but not from outside.
From outside the browser does not have response “Unable to connect” and the curl says:
Failed to connect to example.com port 12443 after 3000 ms: Couldn't connect to server.
What have I missed? Is anybody has an idea why it does not work? If more information needed to investigate the problem, I would try to add it.
Notes
On the predecessor router, I have the rules above, and it just works. W/ the same rules the successor does not.
add action=dst-nat chain=dstnat comment="Port forward" dst-address=89.89.89.89 dst-port=12443 protocol=tcp to-addresses=10.0.1.2 to-ports=443
add action=dst-nat chain=dstnat comment="Hairpin" dst-address=!10.0.1.1 dst-address-type=local dst-port=443 protocol=tcp to-addresses=10.0.1.2 to-ports=443
add action=masquerade chain=srcnat dst-address=!10.0.1.1 dst-port=443 out-interface=bridge protocol=tcp src-address=10.0.1.0/24
