i’m trying to port forward to all my APs so i can reach them out from network.
i have ddns, and can connect to the main mikrotik router that has pppoe on it. when i forward ports, i use dst-nat and enter inbound port, outbound port and ip. that way, for example, i can use ddns.address:port1 to connect to local.ip:80 , since all APs use port 80 for web interface. this is working normal and i can connect to ALL non-mikrotik aps (i have tp-links and ubiquiti) and i can access their web interface from internet.
with mikrotik it’s not working. i tried to both port 80 and access via browser,and port 8291 and access via winbox, but it’s not working. i have 8 mikrotiks in network and this is not working to any of them.
they all have static IP and i can access their web interface from inside the network. but not from outside.
please tell me how to access mikrotiks from internet, and how to configure firewall on the main router.
thank you
Do you have a default route on your AP’s?
/ip route add 0.0.0.0/0 gateway=(router ip)
