I have the following rule:
/ip firewall nat add chain=dstnat dst-address=50.50.50.50 protocol=udp dst-port=5060 action=dst-nat to-addresses=192.168.1.101 to-ports=5060 src-address=100.100.100.100
This works great, except that the src-address is a dynamic address. How can I limit a port forwarding rule to only work from a dynamic address?
Here is the what I am trying to accomplish if that helps. I have a VOIP PBX on a LAN behind a MikroTik router. I have a couple of phone extensions that are in homes outside of the LAN. These home have dynamic addresses. I would like to allow the required VOIP ports to be forwarded to the PBX but only from the specific homes.
Thanks.
