After spending hours trying to get this to work with the default RouterOS setup, I’ve gone with what I can only think is the most basic of router configurations at this point.
I’m simply trying to port forward port 8080 to 192.168.1.102 port 22.
What am I missing?
[admin@MikroTik] > /ip address print detail
0 address=192.168.1.1/24 network=192.168.1.0 interface=ether2
actual-interface=ether2
1 D address=24.xxx.xxx.xx/xx network=24.xxx.xxx.xxx interface=ether1
actual-interface=ether1
[admin@MikroTik] > /ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=24.xxx.xxx.xxx
gateway-status=24.xxx.xxx.xxx reachable via ether1 distance=1 scope=30
target-scope=10 vrf-interface=ether1
1 ADC dst-address=24.xxx.xxx.xxx/xx pref-src=24.xxx.xxx.xxx gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
2 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=ether2
gateway-status=ether2 reachable distance=0 scope=10
[admin@MikroTik] > /interface print detail
0 R name="ether1" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500
l2mtu=1520 max-l2mtu=1520 mac-address=4C:XX:XX:XX:XX:XX fast-path=no
last-link-up-time=dec/19/2015 20:41:43 link-downs=0
1 R name="ether2" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500
last-link-down-time=dec/19/2015 20:46:32
last-link-up-time=dec/19/2015 20:46:40 link-downs=1
2 name="ether3" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500
last-link-down-time=dec/19/2015 20:46:37
last-link-up-time=dec/19/2015 20:42:02 link-downs=2
3 name="ether4" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500
last-link-down-time=dec/19/2015 20:46:41
4 name="ether5" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500
link-downs=0
[admin@MikroTik] > /ip firewall export
# dec/19/2015 21:08:34 by RouterOS 6.33
# software id = PVPD-3MD2
add action=dst-nat chain=dstnat dst-port=8080 in-interface=ether1 protocol=tcp \
to-addresses=192.168.1.102 to-ports=22
