Port Forward help - wireguard
Total Mikrotik Noob here…
Coming from Unifi
after lots of frustration, I got almost everything working, except my vpn.
I’m trying (unsuccessfully) to get my wire guard VPN working
I need to forward udp port 51820 to 192.168.0.222 (my vpn server), using a PPPoE connection
I had everything working with my previous unifi setup, with port 51820 forwarded to the same ip
I’m sure it’s me not understanding something.
Any help would be greatly appreciated .
[admin@MikroTik] > ip firewall export
# jun/12/2022 09:33:13 by RouterOS 7.4beta2
# software id = 0KPK-3LU0
# model = CCR2004-16G-2S+
# serial number = HB********
    established,related,untracked
    invalid
add action=accept chain=forward connection-nat-state=dstnat connection-state=\
    new in-interface-list=WAN
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=input src-address=231.0.0.160
add action=drop chain=input src-address=239.255.255.250
add action=drop chain=input src-address=212.56.101.192
add action=drop chain=input src-address=51.195.234.92
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="drop all else" disabled=yes
add action=dst-nat chain=dstnat in-interface-list=WAN protocol=udp src-port=\
    51820 to-addresses=192.168.0.222 to-ports=51820
i figured out what i did wrong.
when i changed my router from 192.168.0.1 to 192.168.0.2
I forgot that i had dhcp (client) disabled on my rpi which runs wireguard.
and it had the old router address set, which casued all my problems.
I changed it to the new address (rebooted) and it worked.
