Port Forward inside Policy Routing
Hi all,
I trying to get something done, this is what i trying to achieve.
I set up my mikrotik with internet (PPPoE VLAN dynamic ip)
i have standard sets of firewall and NAT rules on my firewall.
so far so good
then i created another pptp client interface (for VPN usage), the VPN gives me a dedicated IP with all ports open
i adjusted Mangle and Routing table so that only certain IP inside LAN will use the VPN
everything still works pretty good
on normal cicumstances, when i do port forward to interface PPPoE, it works good.
but now i trying to achieve port forwarding to the PPTP interface. anyone knows how to do it?
trying to make it works this way…
  1. Normal Standard configuration
    Client → internet → pppoe → port 80 → internal server 192.168.10.10
  2. i am trying port forwarding to VPN
    Client → internet → PPTP → port 80 → internal server 192.168.10.20
what should i do to make it work? do i need to configure extra filter rules? I created NAT rules and it doesnt work…
Thank you in advance.
update:
i am able to port forward after VPN
but when i use NAT Loopback that used “Dst Address Type = local”, port forwarding wont work after VPN.
any forumer can help? please?..
Thnaks
