LAN is 192.168.1.0/24 with bridge-local, eth2,3,4 and wlan, DHCP, everything OK.
I have a DVR with a fixed IP, 192.168.1.150, port 3333.
I did forward the port 3333 using:
chain - dstnat
protocol - tcp
dst port - 3333
in-interface - pppoe-out1
action - dst-nat
to-address - 192.168.1.150
to ports - 3333
If I try to access my public WAN IP:3333 or my Mikrotik free cloud dns name while connected to a different network providing Internet, it works, the port forwarding is ok and I can get to my DVR, but If I try to access my DVR using my public WAN IP:3333 or mikrotik cloud dns name while I’m connected to my local LAN via ethernet or wifi it fails! I can access the dvr using the internal ip, 192.168.1.150:3333 though.
I want to be able to access the DVR using the public wan IP\cloud dns name even if I’m connected to my local LAN.
You need to remove the in-interface filter from your dstnat and put in dst-address-type=local instead. This is because your hairpin traffic won’t be actually coming in the PPPoE interface.
Then add a second hairpin rule to fix certain tcp reply’s:
