First of all proud of such company (because i am Latvian). Heard much about it. Finally got my R750G to give it a try. And to get familiar with RouterOS at all, and i already have that feeling that in some time we will be friends .
After spending some time reading forums and wiki. mikrotik com i still canât get access from outside to my internal server (service tcp on port 9000-9001 of my internal PC 192.168.1.99). It can be also windows remote access or any other service.
Iâll better just try to paste correct part from config just clear out what has gone wrong:
[admin@MikroTik] > /ip firewall nat print all
0 ;;; Added by webbox
chain=srcnat action=masquerade out-interface=ether1-gateway
1 D chain=dstnat action=dst-nat to-addresses=192.168.1.109 to-ports=3442 protocol=tcp dst-address=87.110.170.124 dst-port=3442
2 D chain=dstnat action=dst-nat to-addresses=192.168.1.109 to-ports=3442 protocol=udp dst-address=87.110.170.124 dst-port=3442
3 D chain=dstnat action=dst-nat to-addresses=192.168.1.254 to-ports=32966 protocol=tcp dst-address=87.110.170.124 dst-port=32966
4 D chain=dstnat action=dst-nat to-addresses=192.168.1.254 to-ports=32966 protocol=udp dst-address=87.110.170.124 dst-port=32966
5 chain=dstnat action=dst-nat to-addresses=192.168.1.99 to-ports=9000 protocol=tcp dst-port=9000
6 chain=dstnat action=dst-nat to-addresses=192.168.1.99 to-ports=9001 protocol=tcp dst-port=9001
[admin@MikroTik] > /ip firewall filter print all
chain=input action=accept protocol=icmp
1 ;;; Added by webbox
chain=input action=accept connection-state=established in-interface=ether1-gateway
2 ;;; Added by webbox
chain=input action=accept connection-state=related in-interface=ether1-gateway
3 ;;; logoshana
chain=input action=log in-interface=ether1-gateway log-prefix="Input:Other"
4 ;;; Added by webbox
chain=input action=drop in-interface=ether1-gateway
5 ;;; Added by webbox
chain=forward action=jump jump-target=customer in-interface=ether1-gateway
6 ;;; Added by webbox
chain=customer action=accept connection-state=established
7 ;;; Added by webbox
chain=customer action=accept connection-state=related
8 ;;; Added by webbox
chain=customer action=drop
My outside interface is connected to internet with dynamic IP [DHCP](so it hard for me to specify dst-address for dst-nat), it can change.
Basically my routerboard config is almost default except lines i pasted hare. And settings which i can specify over web access (for example i donât have any clue what means âProtect routerâ, âProtect LANâ and âNATâ in Firewall tab over web access.
[admin@MikroTik] /ip firewall filter> print
3 chain=customer action=accept src-address=192.168.1.99
4 chain=customer action=accept dst-address=192.168.1.99
5 ;;; logoshana
9 ;;; Added by webbox
10 ;;; Added by webbox
Is that the correct place(3,4). And two more questions
How i can change rule order from command line. Had to use winbox to just drag and drop.
What the difference between chain input and chain customer. (I understand that i have to read more about it now, but maybe someone can give me a short hint for this time).
input - used to process packets entering the router through one of the interfaces with the destination IP address which is one of the routerâs addresses. Packets passing through the router are not processed against the rules of the input chain
forward - used to process packets passing through the router
output - used to process packets originated from the router and leaving it through one of the interfaces. Packets passing through the router are not processed against the rules of the output chain
The âcustomerâ chain is a custom, non-built in chain jumped to from the forward chain in your ruleset:
