I’m trying to setup a port forward rule with my pcc setup, but its not working 100%. My port forwards are working through WAN1, but not through WAN2 or WAN3. It only works through WAN2 when I disable WAN1. I’m a bit of noob when it comes to this sort of routing, so any help would be awesome.
My config is as follows:
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17216
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17216
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17216
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN3
add dst-address=0.0.0.0/0 gateway=10.1.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.2.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.3.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.1.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.2.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.3.3.1 distance=3 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add action=dst-nat chain=dstnat dst-port=80,10000 in-interface=WAN1 protocol=tcp to-addresses=172.16.0.2
add action=dst-nat chain=dstnat dst-port=80,6802,6803 in-interface=WAN2 protocol=tcp to-addresses=172.16.10.200
add action=dst-nat chain=dstnat dst-port=25,143,1111,22,110 in-interface=WAN3 protocol=tcp to-addresses=172.16.10.100
From what I understand I’m missing something or something is not right in my marketing. Can someone please help me?
This input chain and output chain rules are affecting traffic to/from the router itself - do you realize that? e.g. Input/output does not refer to traffic WAN<>LAN.
I am also using port forwarding with PCC and it works without any difficulty,
I have dual wan PCC setup. its something like below . . .
DSL1 |
| >>>> RB750 as PCC >>>> RB450G as pppoe server >>> Users
DSL2 |
I wanted to access RB450g Web server (which is running on port 1234)
First I created port forwarding rule on DSL which forward port 1234 to RB750, and I have added following dst-nat rule as below on RB750.
add action=dst-nat chain=dstnat disabled=no dst-port=1234 in-interface=WAN1 protocol=tcp to-addresses=192.168.5.3 to-ports=1234
add action=dst-nat chain=dstnat disabled=no dst-port=1234 in-interface=WAN2 protocol=tcp to-addresses=192.168.5.3 to-ports=1234
192.168.5.3 is RB450G IP address.
Now when I try to access public ip of dsl1 , it simply forward my request to rb750, which again forward it to RB405G and its working fine for me
I’ve revised my config and still can’t get my port forward to work to work on all the lines.
Here is my setup:
[admin@Core Router] > /ip address print
# ADDRESS NETWORK INTERFACE
0 172.16.0.1/16 172.16.0.0 17216
1 172.17.0.1/16 172.17.0.0 17217
2 10.1.1.2/29 10.1.1.0 WAN1
3 10.2.2.2/29 10.2.2.0 WAN2
4 10.3.3.2/29 10.3.3.0 WAN3
/ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 A S dst-address=0.0.0.0/0 gateway=10.1.1.1 gateway-status=10.1.1.1 reachable via WAN1 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_WAN1
1 A S dst-address=0.0.0.0/0 gateway=10.2.2.1 gateway-status=10.2.2.1 reachable via WAN2 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_WAN2
2 S dst-address=0.0.0.0/0 gateway=10.3.3.1 gateway-status=10.3.3.1 unreachable check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_WAN3
3 A S dst-address=0.0.0.0/0 gateway=10.1.1.1 gateway-status=10.1.1.1 reachable via WAN1 check-gateway=ping distance=1 scope=30 target-scope=10
4 S dst-address=0.0.0.0/0 gateway=10.2.2.1 gateway-status=10.2.2.1 reachable via WAN2 check-gateway=ping distance=2 scope=30 target-scope=10
5 S dst-address=0.0.0.0/0 gateway=10.3.3.1 gateway-status=10.3.3.1 unreachable check-gateway=ping distance=3 scope=30 target-scope=10
6 ADC dst-address=10.1.1.0/29 pref-src=10.1.1.2 gateway=WAN1 gateway-status=WAN1 reachable distance=0 scope=10
7 ADC dst-address=10.2.2.0/29 pref-src=10.2.2.2 gateway=WAN2 gateway-status=WAN2 reachable distance=0 scope=10
8 DC dst-address=10.3.3.0/29 pref-src=10.3.3.2 gateway=WAN3 gateway-status=WAN3 unreachable distance=0 scope=255
9 ADC dst-address=172.16.0.0/16 pref-src=172.16.0.1 gateway=17216 gateway-status=17216 reachable distance=0 scope=10
10 ADC dst-address=172.17.0.0/16 pref-src=172.17.0.1 gateway=17217 gateway-status=17217 reachable distance=0 scope=10
/ip firewall mangle print
0 chain=output action=mark-routing new-routing-mark=to_WAN1 passthrough=yes connection-mark=WAN1_conn
1 chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=yes connection-mark=WAN2_conn
2 chain=output action=mark-routing new-routing-mark=to_WAN3 passthrough=yes connection-mark=WAN3_conn
3 chain=prerouting action=accept dst-address=10.1.1.0/29 in-interface=17216
4 chain=prerouting action=accept dst-address=10.2.2.0/29 in-interface=17216
5 chain=prerouting action=accept dst-address=10.3.3.0/29 in-interface=17216
6 chain=prerouting action=accept dst-address=10.1.1.0/29 in-interface=17217
7 chain=prerouting action=accept dst-address=10.2.2.0/29 in-interface=17217
8 chain=prerouting action=accept dst-address=10.3.3.0/29 in-interface=17217
9 chain=input action=mark-connection new-connection-mark=WAN1_conn passthrough=yes in-interface=WAN1 connection-mark=no-mark
10 chain=input action=mark-connection new-connection-mark=WAN2_conn passthrough=yes in-interface=WAN2 connection-mark=no-mark
11 chain=input action=mark-connection new-connection-mark=WAN3_conn passthrough=yes in-interface=WAN3 connection-mark=no-mark
12 chain=prerouting action=mark-connection new-connection-mark=WAN1_conn passthrough=yes dst-address-type=!local in-interface=17216 connection-mark=no-mark per-connection-classifier=both-addresses:3/0
13 chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes dst-address-type=!local in-interface=17216 connection-mark=no-mark per-connection-classifier=both-addresses:3/1
14 chain=prerouting action=mark-connection new-connection-mark=WAN3_conn passthrough=yes dst-address-type=!local in-interface=17216 connection-mark=no-mark per-connection-classifier=both-addresses:3/2
15 chain=prerouting action=mark-connection new-connection-mark=WAN1_conn passthrough=yes dst-address-type=!local in-interface=17217 connection-mark=no-mark per-connection-classifier=both-addresses:3/0
16 chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes dst-address-type=!local in-interface=17217 connection-mark=no-mark per-connection-classifier=both-addresses:3/1
17 chain=prerouting action=mark-connection new-connection-mark=WAN3_conn passthrough=yes dst-address-type=!local in-interface=17217 connection-mark=no-mark per-connection-classifier=both-addresses:3/2
18 chain=prerouting action=mark-routing new-routing-mark=to_WAN1 passthrough=yes in-interface=17216 connection-mark=WAN1_conn
19 chain=prerouting action=mark-routing new-routing-mark=to_WAN2 passthrough=yes in-interface=17216 connection-mark=WAN2_conn
20 chain=prerouting action=mark-routing new-routing-mark=to_WAN3 passthrough=yes in-interface=17216 connection-mark=WAN3_conn
21 chain=prerouting action=mark-routing new-routing-mark=to_WAN1 passthrough=yes in-interface=17217 connection-mark=WAN1_conn
22 chain=prerouting action=mark-routing new-routing-mark=to_WAN2 passthrough=yes in-interface=17217 connection-mark=WAN2_conn
23 chain=prerouting action=mark-routing new-routing-mark=to_WAN3 passthrough=yes in-interface=17217 connection-mark=WAN3_conn
/ip firewall nat print
0 ;;; NAT:
chain=srcnat action=masquerade out-interface=WAN1
1 chain=srcnat action=masquerade out-interface=WAN2
2 chain=srcnat action=masquerade out-interface=WAN3
3 ;;; WAN1 Port Forwards:
chain=dstnat action=dst-nat to-addresses=172.16.0.2 to-ports=80 protocol=tcp in-interface=WAN1 dst-port=80
4 chain=dstnat action=dst-nat to-addresses=172.16.0.2 to-ports=10000 protocol=tcp in-interface=WAN1 dst-port=10000
5 chain=dstnat action=dst-nat to-addresses=172.16.10.200 to-ports=6802 protocol=tcp in-interface=WAN1 dst-port=6802
6 chain=dstnat action=dst-nat to-addresses=172.16.10.200 to-ports=6803 protocol=tcp in-interface=WAN1 dst-port=6803
7 ;;; WAN2 Port Forwards:
chain=dstnat action=dst-nat to-addresses=172.16.10.200 to-ports=80 protocol=tcp in-interface=WAN2 dst-port=80
8 chain=dstnat action=dst-nat to-addresses=172.16.10.200 to-ports=6802 protocol=tcp in-interface=WAN2 dst-port=6802
9 chain=dstnat action=dst-nat to-addresses=172.16.10.200 to-ports=6803 protocol=tcp in-interface=WAN2 dst-port=6803
10 ;;; WAN3 Port Forwards:
chain=dstnat action=dst-nat to-addresses=172.16.10.100 to-ports=25 protocol=tcp in-interface=WAN3 dst-port=25
11 chain=dstnat action=dst-nat to-addresses=172.16.10.100 to-ports=143 protocol=tcp in-interface=WAN3 dst-port=143
12 chain=dstnat action=dst-nat to-addresses=172.16.10.100 to-ports=1111 protocol=tcp in-interface=WAN3 dst-port=1111
13 chain=dstnat action=dst-nat to-addresses=172.16.10.100 to-ports=22 protocol=tcp in-interface=WAN3 dst-port=22
14 chain=dstnat action=dst-nat to-addresses=172.16.10.100 to-ports=110 protocol=tcp in-interface=WAN3 dst-port=110
I followed the advice on http://forum.mikrotik.com/t/port-forwarding-with-pcc/41642/1 Please can someone help? I’m not sure what I am missing?
