Port forward on ZeroTier
I have a ZeroTier network setup for VPN. This was the easiest option to get remote access in a dual WAN (Starlink + Telekom VDSL) with the original routers in place and all dynamic addresses. On the remote network ZeroTier is setup on a RB3011.
Network setup: admin Mac (ZeroTier address 192.168.193.227) ↔ ZeroTier network 192.168.193.0/24 ↔ RB3011 (ZeroTier address 192.168.193.222, LAN address 192.168.0.2) ↔ remote LAN 192.168.0.0/24 ↔ another mikrotik (192.168.0.1)
Now I can perfectly fine access the 192.168.193.222 box. But I also want to access another device on the remote LAN, 192.168.0.1 (I cannot setup ZeroTier on it).
So this works:
  • on the admin Mac: ssh admin@192.168.193.222 -L 8291:192.168.0.1:8291
  • and then I can use WinBox with localhost:8291 to access 192.168.0.1:8291 in the remote network.
What I would like is to configure a port forward on the RB3011 to map to the remote device on the LAN. So on 192.168.193.222:8292 to map to 192.168.0.1:8291.
I would be even better to use 192.168.193.1 to map all ports to 192.168.0.1.
I have tried the following NAT rule but that does not work:
/ip/firewall/nat> print detail
Flags: X - disabled, I - invalid; D - dynamic
 0    chain=srcnat action=masquerade protocol=tcp src-address=192.168.0.0/24 dst-address=192.168.0.1 out-interface=LAN log=yes
 1    chain=dstnat action=dst-nat to-addresses=192.168.0.1 to-ports=80 protocol=tcp dst-address=192.168.193.222 in-interface=zerotier1 dst-port=81 log=yes
According to Normis, the zerotier documentation is amazing.
I have found quite the opposite, and as for MT documentation… ???
You are missing a src-nat for the ZeroTier network. It should look like your first rule with the src-address=192.168.193.0/24 and to-address=192.168.0.2. Or you can put a route to 192.168.193.0/24 on the remote Mikrotik pointing to 192.168.0.2.
Thanks that fixed it. So if I understand correctly I was missing the route back from 192.168.0.1 to 193.168.193.222 via the 192.168.0.2?
For others:
 1    chain=srcnat action=masquerade to-addresses=192.168.0.2 protocol=tcp src-address=192.168.193.0/24
 2    chain=dstnat action=dst-nat to-addresses=192.168.0.1 to-ports=8291 protocol=tcp dst-address=192.168.193.222 in-interface=zerotier1 dst-port=8292
