port forward to metarouter
Ok so I setup ddwrt on a meta router. I can get to the ssh local over the tik through putty so i am good to that point. However i can not get to ssh when coming in remotely. I tired port forwarding and even chaging the ssh port in case 22 was still be caught through the miktoiks interface but no good.
My metarouter sits on 192.168.80.2 so all I did was set up a port forward rule 2222 to go to 192.168.80.2
chain=dstnat action=dst-nat to-addresses=192.168.80.2 to-ports=2222 protocol=tcp dst-port=2222
What am I missing?
maybe only the correct gateway on ddwrt ?
I think I already had that or is it somewhere else?
Copyright (C) 2006 OpenWrt.org
config interface loopback
option ifname lo
option proto static
option ipaddr 127.0.0.1
option netmask 255.0.0.0
config interface lan
option ifname eth0
option type bridge
option proto static
option ipaddr 192.168.80.2
option netmask 255.255.255.0
option gateway 192.168.80.1
If you use the private IP of the Metarouter while on the LAN (no hairpin NAT):
/ip firewall nat add chain=dstnat in-interface=WAN protocol=tcp dst-port=2222 action=dst-nat to-address=192.168.80.2 to-ports=22
(replace WAN with the name of your WAN interface, e.g. pppoe-out-1, ether1, etc)
If you want hairpin access:
..and have a static IP:
Use the above rule but remove in-interface=WAN and add dst-address=x.x.x.x (your wan IP).
…and have a dynamic IP:
USe the above rule but remove in-interface=WAN and add dst-address-type=local and dst-address=!192.168.80.1
With either of these changes, for hairpin to work, you will also need to add an additional srcnat rule:
/ip firewall nat add chain=srcnat src-address=192.168.80.0/24 dst-address=192.168.80.0/24 action=masquerade
Allow access:
Finally, make sure that the filter table is not blocking the access to your metarouter. The forward chain is the one to check. If your forward chain is a “default deny” type of configuration, then there needs to be a rule which permits tcp dst-port=22 dst-address=192.168.80.2 (Note that dst port is 22 because the forward filter chain is checked AFTER dst-nat has executed)
If your forward chain is a “default accept” policy, then make sure there is no rule which blocks access to your server.
That was it thanks again
