I’m quite new in mikrotik.
I have 2 internet lines and i’m trying to forward port 80 to an internal address. As long as both lines are connected, port forward works from both real IP-s. But if i disconnect the first line, then second disconnects also and it stops working. The opposite works anyway…
So, how can i configure both lines to work, independently from each other? I masqueraded both lines and used 2 nat-s to forward from each real IP address…
Can someone help me?
Thank you!
