Below my network map. I’m trying to access ip camera outside lan.
As you can see everything is behind NAT.
Should I bridge one layer instead of NAT layer?
I don’t know how to set port forwarding.
All hardware (except for the camera) is based on routerOS
Forwarding port 80 is almost always a bad idea, because there is so many things using port 80, not least of all web pages. In this case you would create a firewall rule in access point firewall dst-nat with dst ip 192.168.6.1 and action dst-ip = 192.168.0.100 This will route all traffic coming in on 192.168.6.1 to 192.168.0.100. Would probably be a good idea to create rule with masquerading on the interface going from AP to camera. Would be better to change camera ip to, as example port 808, in which case you would change firewall rule to include dst-port 808.
sorry for my ignorance, I am newbie…
so you suggest to forward all traffic comin on modem 192.168.6.1 to 192.168.0.100 through port 808?
Rules you posted are to be set into modem?
Where do I run dynamic dns client?
Is ip routing involved with port forwarding?
There are too many nodes (NAT) involved in that map which is not good. If you can I would recommend to bridge them until you serve the final network.
Anyway, there are two ways to reach to your camera. First is by doing a nat rule on every node:
this rule is placed on modem and will forward the request on port 8080 to the access point with address=192.168.6.10. Obviously the syntax for the modem is different, but you get the idea
These rules, each one placed on the respective nodes (modem, access point, next one) are basically telling the modem where to find the network 192.168.0.0/24 where your IP Camera is. Once the modem finds the camera, just add a dstnat on the modem with destination 192.168.0.100
now it’s very clear caci99..thanks
but how about dynamic dns client? Shouldn’t I run it?
Which way is better between forwarding and ip routing?
I’d like to keep my current configuration, I feel safe with NAT…
You mean dhcp client? What about them? If you mean that tey do have a dynamic IP because of the dhcp server, then you can force the dhcp server to give them the same IP by setting the client as static in the lease table of dhcp server.
Basically is just the same. I would have used static routing because it might come at hand for future configurations.
