first time using MikroTik and RouterOS! ![]()
I have two VLANs (10 and 20) set up on one interface, and one WAN interface. VLANs can access each other and the internet. But for the life of me I can’t seem to set up port forwarding… I’ve tried everything I could find online.
I have to forward the port 80 of the host 172.16.0.8 (on VLAN 10).
I have no filters set up! I have also moved the WebFig to 8080.
Here is my config:
Interfaces:
0 R name="ISP" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=4074 mac-address=E4:[REDACTED] fast-path=yes last-link-up-time=jul/18/2015 07:19:37 link-downs=0
8 R name="lan" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=4074 mac-address=E4:[REDACTED] fast-path=yes last-link-up-time=jul/18/2015 07:21:14 link-downs=0
11 R name="VLAN10" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1594 mac-address=E4:[REDACTED] fast-path=no last-link-up-time=jul/18/2015 07:21:14 link-downs=0
12 R name="VLAN20" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1594 mac-address=E4:[REDACTED] fast-path=no last-link-up-time=jul/18/2015 07:21:14 link-downs=0
Firewall:
0 chain=srcnat action=masquerade out-interface=ISP log=no log-prefix=""
1 chain=srcnat action=masquerade out-interface=lan log=no log-prefix=""
2 chain=srcnat action=masquerade out-interface=VLAN10 log=no log-prefix=""
3 chain=srcnat action=masquerade out-interface=VLAN20 log=no log-prefix=""
4 chain=dstnat action=dst-nat to-addresses=172.16.0.8 to-ports=80 protocol=tcp in-interface=ISP dst-port=80 log=no log-prefix=""
Thank you very much!!
More info:
I have another router set up in front of MicroTik, an ISP’s POS thing that I can’t get rid of. I have set up port forwarding there to the correct settings that worked before when I was using a Cisco router in the same configuration. I can’t access the forwarded port either from the Internet, nor from the ISP’s router network (192.168.5.0/24).
