I have been getting an error code pretty frequently for destiny 2 (cabbage)
there a few solutions that I have tried, by default upnp was off on my mikrotik router, so i turned that on and rebooted, same issue.
the next is port forwarding/opening.
I don’t know if my pc’s IP address changes because of DHCP or if I would have to turn off that setting in order to port forward.
On their website it says to open these ports:
TCP: 80, 443, 1119-1120, 3074, 3724, 4000, 6112-6114, 7500-7509, 30000-30009
UDP: 80, 443, 1119-1120, 3074, 3097-3196, 3724, 4000, 6112-6114, 27015-27200
and to forward these ports:
UDP: 3074, 3097
I tried looking up guides, mikrotik specific guides about port forwarding, and I could not put two and two together about opening and forwarding the destiny 2 specific ports.
Thank you in advance, let me know if I need to add more details. Below is router config
# jun/13/2024 17:35:51 by RouterOS 6.49.15
# software id =
# model = RB760iGS
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip upnp
set enabled=yes show-dummy-rule=no
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
