Dear All,
This is my first query on this forum.
I am using RB450 with winbox OS 5.6.
I want to access one of my LAN pc over web-access.
I want to do port forwarding.
My current configuration for Mikrotik is
ADDRESS NETWORK INTERFACE
0 ;;; WAN
XXX.XXX.XXX.XXX/24 XXX.XXX.XXX.XXX ether1
1 ;;; LAN
192.168.0.250/24 192.168.0.0 ether5
then I have gone through the document and wrote the code
0 chain=dstnat action=redirect to-ports=2138 protocol=tcp in-interface=ether5 dst-port=80
2 ;;; Server Remote Access
chain=dstnat action=dst-nat to-addresses=192.168.0.63 to-ports=80 protocol=tcp in-interface=ether1 dst-port=80
but still I am unable to access the PC (192.168.0.63) with port 80 through web access .
So please tell me how I should configure to get web access of a PC which is connected in my LAN.
Thanks in advance .
Thanks for ur help but still I am unable to get that PC through web access.
Can u please tell me that “do I need to put the static ip provided by our ISP which was used in WAN port of Mikrotik router”?
Or if u can just show me step by step configuration pics which can be possible through WinBox?
If your ISP assign you static IP and you want to access the web server through this, you need to put your static IP instead of x.x.x.x in the above code, just this. you must be sure that the PC (192.168.0.3) will accept packets to port 80
what do you want to do? do you have any web server(because you mentioned to port 80) on your PC? or want to access through remote desktop?
tell me what do you want to do exactly then I can help you with step by step configuration.
What will be the figure there in place of x.x.x.x?
also can u please tell me that if the port mentioned is 80 then will it work as remote access or not?
x.x.x.x should be the public IP of your router which you want to access it.
0 ;;; WAN
122.170.14.211/24 122.170.14.211 ether1
122.170.14.211
Can you tell me what do you mean by “remote access” ?
Port 80 is a registered port for HTTP and you can use it if you have a web server on your PC.
When you are planning to access to your PC through remote desktop(In Microsoft windows), the windows remote desktop terminal use port 3389.
I am actually willing to access/view all my reports which are there on my server through http address.
Right now I used to do it for local network only (http://hopesrv4/Reports/Pages/Folder.aspx).
The report generating software is maintained by some other agency and they asked me to do the port forwarding for port no 80.
And I want to do port forwarding so that this webaddress (http://hopesrv4/Reports/Pages/Folder.aspx) can also be accessed from anywhere in the world.
So can you please tell me that with the NAT rule I was asking will suffice my need?
If possible can you give me your any of messenger id (gmail, hotmail, yahoo) so that I can chat you live?
Waiting for reply.
Thanks in advance.
