Hello, I am trying to forward ports to apache (and some other services, such as plex, VPN, etc.) but with no success. When I am inside the lan or VPN apache I can connect to apache with public IP adress (or domain). But when I am outside of Lan it is not posible. It does not work even if I turn off all firewall rules. When I turn them off I can directly connect to routerboard web GUI.
Here is my log from IP Firewall:
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” connection-state=
established,related
add chain=input dst-port=1723 protocol=tcp
add chain=input protocol=gre
add action=log chain=input limit=5/1m,5
add action=drop chain=input comment=“default configuration” in-interface=
ether1-gateway
add chain=forward comment=“default configuration” connection-state=
established,related
add chain=forward dst-port=1723 protocol=tcp
add chain=forward protocol=gre
add chain=forward dst-port=32400 protocol=tcp
add action=log chain=forward limit=5/1m,5
add action=drop chain=forward comment=“default configuration”
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=
ether1-gateway
add action=masquerade chain=srcnat comment=“default configuration”
out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-address=213.192.30.62 dst-port=
protocol=tcp to-addresses=192.168.88.2 to-ports=80
add action=masquerade chain=srcnat out-interface=ether1-gateway
add action=masquerade chain=srcnat dst-address=192.168.88.2 dst-por
out-interface=bridge-local protocol=tcp src-address=192.168.88.
in-interface=ether1-gateway protocol=tcp to-addresses=192.168.8
to-ports=1723
add action=dst-nat chain=dstnat dst-address=213.192.30.62 in-interf
ether1-gateway protocol=gre to-addresses=192.168.88.2
add chain=srcnat
protocol=tcp to-addresses=192.168.88.2 to-ports=32400
Please help, thank you!
