Port forwarding behind isp 1:1 nat
I have following setup:
ISP Router <=> Mikrotik <=> LAN
ISP Router has public IP address 176.X.X.X and LAN 192.168.1.0/30 with 1:1 NAT (176.X.X.X <=> 192.168.1.1) and DMZ set for 192.168.1.2
Mikrotik is connected over ETH1 with ISP Router and get IP address 192.168.1.2/30 with gateway 192.168.1.1. EHT2-5 are connected to the LAN with IP 192.168.88.0/24
Internet is working fine, all workstations can access the internet, also L2TP VPN client from Mikrotik is connecting to other mikrotik router.
Now I’m trying to allow access to the NAS 192.168.88.12 on port 5001 from outside. I have created the following rule:
add action=dst-nat chain=dstnat dst-port=5001 protocol=tcp to-addresses=192.168.88.12 to-ports=5001
But this not seems to work, no packet is send through to the Mikrotik. Could you please help me to solve this problem?
You need to post your config
Here you are:
# may/12/2020 08:33:05 by RouterOS 6.46.6
# model = 951G-2HnD
add admin-mac=4C:5E:0C:A2:55:57 arp=proxy-arp auto-mac=no comment=defconf name=bridge protocol-mode=none
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.100
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge interface=*C
set discover-interface-list=all
/interface l2tp-server server
set default-profile=vpn enabled=yes max-mru=1500 max-mtu=1500 use-ipsec=yes
/interface pptp-server server
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1 wins-server=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log-prefix=INVALID
add action=accept chain=input comment=gre protocol=gre
add action=accept chain=input comment=pptp dst-port=1723 protocol=tcp
add action=accept chain=input comment=l2tp dst-port=1701,500,4500 protocol=udp
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=WAN log=yes log-prefix=3333
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid log=yes log-prefix=2222
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN log-prefix=1111
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.88.0/24,192.168.12.0/23
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.88.0/24,192.168.12.0/23
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=Mikrotik
/tool mac-server
/tool mac-server mac-winbox
You have a double firewall though don’t you? Why isn’t the ISP router in Bridge mode? If I understand correctly you have a router plugged into a router. It seems that way from the IPs you’re indicating. This will cause you headaches like this.
According to ISP their router has set up DMZ, so everything should go through directly to my router. Unfortunately the ISP can’t set it into bridge mode.
I have discussed the issue with ISP and it the problem was on their side. Everything is working now. You can close the thread.
