Quick background:
Attempting to get OpenVPN running on network using a raspberry pi. I have the server configured, client configurations distributed, etc. UFW on the pi has both 443/tcp and 1194/udp open.
DST-NAT on the router appears to be broken. I cannot forward or open ANY ports in NAT and I’m 99% certain I have the rules appropriately configured.
I’ve pasted my firewall config below. Local VPN address is 192.168.88.94.
add action=passthrough chain=forward dst-port=44695 log=yes log-prefix=44695_forward protocol=tcp
add action=passthrough chain=input dst-port=44695 log=yes log-prefix=44695_input protocol=tcp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=dst-nat chain=dstnat comment=OpenVPNServer_UDP/1194 dst-address=192.168.88.94 dst-port=1194 log=yes \
log-prefix=OpenVPN_UDP protocol=udp to-addresses=192.168.88.94 to-ports=1194
add action=dst-nat chain=dstnat comment=OpenVPNServer_TCP/443 dst-address=192.168.88.94 dst-port=443 log=yes \
log-prefix=OpenVPN_TCP protocol=tcp to-addresses=192.168.88.94 to-ports=443
To troubleshoot, I added a couple rules to the router firewall filter:
…and pushed them to the top of the list.
In telnet, I try to open a connection to my home IP via port 44695 and connection fails:
Connecting To 69.207.177.35...Could not open connection to the host, on port 44695: Connect failed
However, the INPUT chain rule above receives packets and data, while the FORWARD chain rule does not show any traffic.
Not sure what is causing packets to be blocked despite having NAT configured. Help is appreciated.
