Port forwarding external/internal network.
Hi, I have a little problem with the configuration of Mikrotik. I will explain my situation so it will be easier.
The old system (cisco system):
I have connected to Mikrotik (RJ45) device, TV, QNQP server and another computer. And wifi.
To gain access to these devices I added port forwarding for ftp, for the web, for vpn and QNAP. On the external network I join the same address as the local network. And so it is good.
The new system (mikrotik):
If I set port forwarding for those same ports to access the internal network have to use other addresses for external network and internal network. You can set the Mikrotik to the same as the cisco system can use a single address?
My English is not very good, I hope that is understood.
Thank you for your help.
