Hi!
I’ve some test domain that are connected to my external ip connection, on my mikrotik I’ve a rule that forwart that request to a local machine and it goes, but when from a local pc I try to connect using the external ip I can’t connect:
External PC → https://test.domain.it:9444 (https://1.2.3.4:9444) → 192.168.1.2:443 OK
PC from same LAN 192.168.1.230 → https://test.domain.it:9444 (https://1.2.3.4:9444) FAILS
My nat rule is:
add action=dst-nat chain=dstnat dst-port=9444 log=yes log-prefix=NAT protocol=tcp to-addresses=192.168.1.2 to-ports=443
and some log from the NAT rule:
10:29:51 echo: firewall,info NAT dstnat: in:ether5-LAN out:(unknown 0), src-mac 11:22:33:44:55:00, proto TCP (SYN), 192.168.111.240:35092->1.2.3.4:9444, len 60
10:29:51 echo: firewall,info NAT dstnat: in:ether5-LAN out:(unknown 0), src-mac 11:22:33:44:55:00, proto TCP (SYN), 192.168.111.240:35094->1.2.3.4:9444, len 60
10:29:51 echo: firewall,info NAT dstnat: in:ether5-LAN out:(unknown 0), src-mac 11:22:33:44:55:00, proto TCP (SYN), 192.168.111.240:35098->1.2.3.4:9444, len 60
