can I port forwarding range of ports in one NAT rule??
I mean if you want to port forward range of ports 8220-8335 TCP/UDP , is it possible to do it in one or two NAT rule???
thanks in advance
thanks in advance
Yes it is possible with 2 rules. One for TCP and one for UDP.
chain=dstnat action=dst-nat to-addresses=x.x.x.x
to-ports=8220-8335 protocol=udp in-interface=WAN_Interface
dst-port=8220-8335 log=no log-prefix=""
to-ports=8220-8335 protocol=tcp in-interface=ether1
Just replace IP address and interface to suit your needs.
