Port forwarding help
Hello!
I have a hAP ac2 and i have problem with port forwarding.
I have 2 pc (192.168.1.18, 192.168.1.19) playing the same games and using the same softwares on both.
Ports: 3478-3479,4379-4380,3074,7777-7778,25147,27000-27100
Playing steam games and running game servers.
I need the open the same ports on both pcs, but idk how can i.
Eg. Running ARK server on .18 in 27015 port, when playing team fortress 2 in other pc (.19) on the same 27015 port. Sometimes i join from .19 to .18 server (27015 port)
I hope its understandable, please help me to configure this mess.
An Endpoint (combination IP address and port) is unique, hence you can only forward a port once.
To options to handle this situation:
  1. different IP address
  2. different port
As the port is fixed (by Steam), only a second public IP address would solve this problem. Can your provider supply you multiple IP addresses? Or perhaps IPv6 would be a solution…
