Port Forwarding is blocking outbound traffic
Hey guys and gals,
I setup a routerOS box(RB400G I think?) and I’m running 5.14 at the moment.
I’m not sure how to export my list of firewall rules, but I’d be happy to paste them here.
I did a simple thing like this, but using winbox.
add chain=dstnat action=dst-nat to-addresses=192.168.1.202 to-ports=8152 \
    dst-address=202.59.xx.xx. dst-port=8152 protocol=tcp comment="" disabled=no
My problem is this, when I have the rule (not above, its just a sample) enabled, I cannot FTP out to any sites from within my network. Once I disable it, all works fine.
I must have something misconfigured.
Any ideas?
I just did print from the nat menu in the terminal
3 X ;;; FTP to FS
chain=dstnat action=dst-nat to-addresses=10.0.0.80 to-ports=21
protocol=tcp dst-port=21
Firewall rules can be exported by “/ip firewall export”
When enabled this rule will forward all TCP/21 traffic ti 10.0.0.80. Specify in-interface or dst-address to apply it only for public traffic.
Thank you Very much! That’s exactly what I needed.
So I set the interface to my gateway, but if I set a dst address, would that be the public IP or the internal ip of the machine forwarded to?
Use public IP, if you need to forward traffic coming to public interface.
