Hi all,
I’m new to Mikrotik kit and have so far managed to replicate the configuration held on our old Draytek kit and all appears to be working fine. VPN, VLAN’s you name it - all work perfectly.
So then I moved onto port forwarding, which I (perhaps naively) thought would be simple. But I’m having an issue.
I’ve set up dstnat and forwarded the appropriate port to a LAN IP. I can access the server via the LAN IP when connected to the LAN, but when I try connecting via the WAN IP via a PC connected to the LAN it just times out. If I try and connect to the server via the WAN IP from a separate cellular connection it works perfectly.
So it appears there’s a configuration issue that’s stopping me accessing WAN resources over certain ports. I’m almost certain it’s firewall related but after spending a fair bit of time researching and attempting trial and error solutions I’m at a loss as to exactly how to resolve this.
Any guidance you can offer would be greatly appreciated!
Many thanks,
Ollie
