Port forwarding issue
Hello!
I can not make it work. Try to forward port 222 to 22 on 192.168.1.33.
All drop firewall filter rules was disabled.
Please help me figure out what the issue is.
My config:
apr/16/2020 12:37:22 by RouterOS 6.46.5
model = RouterBOARD 952Ui-5ac2nD
add admin-mac=::::: auto-mac=no comment=defconf igmp-snooping=yes name=bridge
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-XX country=russia disabled=no distance=indoors frequency=auto hw-protection-mode=rts-cts installation=
indoor mode=ap-bridge ssid=*** wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=russia disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower hw-protection-mode=cts-to-self installation=
indoor mode=ap-bridge radio-name=mthome ssid=*** wireless-protocol=802.11 wmm-support=enabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=*** wpa2-pre-shared-key=***
/ip hotspot profile
add name=dhcp ranges=192.168.1.2-192.168.1.100
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-server lease
add address=192.168.1.2 client-id=1:::::: mac-address=::::** server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=forward dst-port=1802 protocol=tcp
add action=accept chain=forward dst-port=80 protocol=tcp
add action=accept chain=forward dst-port=222 protocol=tcp
add action=accept chain=input comment="Allow IGMP" protocol=igmp
add action=accept chain=input comment="Allow UDP" protocol=udp
add action=accept chain=forward comment="Allow UDP" protocol=udp
add action=accept chain=forward dst-port=1802 in-interface-list=WAN protocol=tcp
add action=accept chain=forward dst-address=192.168.1.2 dst-port=1802 protocol=tcp
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=netmap chain=dstnat dst-port=222 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.1.33 to-ports=22
/routing igmp-proxy
set query-interval=30s query-response-interval=20s
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=ether1 upstream=yes
add interface=bridge
/tool mac-server
/tool mac-server mac-winbox
add action=accept chain=forward dst-port=222 protocol=tcp - Should be chain=input not forward
add action=netmap chain=dstnat dst-port=222 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.1.33 to-ports=22 - action dst-nat, not netmap
Already try this. Can’t help.
But check it again now:
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=input dst-port=222 protocol=tcp
add action=accept chain=input comment=“Allow IGMP” protocol=igmp
add action=accept chain=input comment=“Allow UDP” protocol=udp
add action=accept chain=forward comment=“Allow UDP” protocol=udp
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid disabled=yes
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid disabled=yes
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=222 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.1.33 to-ports=22
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
Don’t work :frowning:
I have no idea what you are trying to accomplish here…
But remove the rules in red to start with and go back to default settings and then build up rules as necessary.
TO This should work!!
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid disabled**=NO**
add action=drop chain=input comment=“defconf: drop all not coming from LAN” disabled**=NO** in-interface-list=!LAN
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid disabled**=NO**
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new disabled**=NO** in-interface-list=WAN
Changed the config to:
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
And nothing has changed.
I also tried to remove all the rules from the filter section.
The setup I provided works, and thus the issue is some other part of your config.
Please provide a complete config…
I have already provide the full configuration at first post.
Looks like an issue on the operator side.
