Port Forwarding Issue
Please help me I am new in this field and requested many people but no one helped me. The issue is :
I am unable to access winbox from other network or city via port forwarding. I am having two systems
a. RB 750 as Load Balancer (Script Attached)
b. x86 for Hotspot (Script Attached)
I will be very thankful to you all genius people and please help me .
Thanks.
Muhammad Fawad
LoadBalancer_Export.rsc (16.6 KB)
Hotspot_Export.rsc (26.8 KB)
cursols,
The problem is that you didn’t create the INPUT and OUTPUT rules. This will ensure that if you connect through wan1 it will back through wan1.
Like this:
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=WAN1 new-connection-mark=UP_01 passthrough=yes
add action=mark-routing chain=output connection-mark=UP_01 disabled=no new-routing-mark=UP_01 passthrough=yes
Make this to all links that you have, ok?
Dear Friend,
I am very thankful for your kind help. Please let me know on which machine( load balancer or hotspot) should I have to put these rules.
Thank you again.
Only in the load balance RB.
May I have your email address please.
No Sir. It did not work.
Please check my DSL modem settings also.
