Port forwarding issue
Hello!
I’m trying to do simple port forwarding to port 80 (local webserver) on local NAT network. Something is wrong though - i see packets increase for this rule on Winbox when i try to access port 80 on outside interface (IP 5.5.5.5), but still httpd is unreachable. I tried to change some settings on SMTP port forward also, but had no luck either. I can access local web server from local network fine.
Outside interface has ISP assigned IP : 5.5.5.5
Inside interface has 10.10.10.0/24 network attached to it
Webserver is located on IP: 10.10.10.11
 /ip address print detail
 0   address=10.10.10.1/24 network=10.10.10.0 interface=Inside actual-interface=Inside
 1 D address=5.5.5.5/19 network=5.5.5.0 interface=Outside actual-interface=Outside
add action=masquerade chain=srcnat disabled=no out-interface=Outside
add action=dst-nat chain=dstnat comment="http port forward to freebsd box" disabled=no dst-address=5.5.5.5 dst-port=80 in-interface=Outside protocol=tcp to-addresses=\
    10.10.10.11 to-ports=80
add action=dst-nat chain=dstnat comment="SMTP forward to Postfix server" disabled=no dst-port=25 in-interface=Outside protocol=tcp to-addresses=10.10.10.11 to-ports=25
/ip route print detail
 0 ADS  dst-address=0.0.0.0/0 gateway=5.5.5.1 gateway-status=5.5.5.5.1 reachable via  Outside distance=0 scope=30 target-scope=10 vrf-interface=Outside
 1 ADC  dst-address=10.10.10.0/24 pref-src=10.10.10.1 gateway=Inside gateway-status=Inside reachable distance=0 scope=10
 2 ADC  dst-address=5.5.5.0/19 pref-src=5.5.5.5 gateway=Outside gateway-status=Outside reachable distance=0 scope=10
I have disabled all firewall filter rules.
This is on RouterOS 5.15
Any ideas what the issue could be? Thanks.
I forgot to mention that webserver is located on Vmware Guest OS on Win7 which had local firewall. Disabled it and everything now works fine.
That was one stupid mistake. Got my lesson. Sorry.
