Port forwarding issue
Hello to all
I’m pretty new on this Mikrotik boards and they are already winning the battle.
I need to configure a simple port forwarding NAT rule to access my DVR from the internet on port 8016.
this is what I’ve done:
/ip firewall nat add chain=dstnat dst-address=69.69.69.69 protocol=tcp dst-port=8016
action=dst-nat to-addresses=10.1.3.185 to-ports=8016
69.69.69.69 replaced by my real external IP address.
I was doing research and everyone says that is as simple as creating that nat rule… but is not working.
How can I identify what is blocking those connections?
Please help me not to start hating this devices :frowning:
Thanks in advance,
It would help to post your config so we can see what’s going on.
Also, It would be easier to use the Netmap action, with in-interface specified, to perform port forwarding. This way you won’t have to modify your rule if your external IP changes.
add action=netmap chain=dstnat comment="Your Comment" disabled=no dst-port=8888 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.1.50
Are you accepting the dst port in forward chain?
Hello, thank you all for the replies.
Right now I’m forwarding the port 8016 (the DVR port) on a Forward rule also.
I already have a Static IP address so there is no problem of the IP changing.
How may I send you my actual configuration?
Any ideas?
You haven’t posted your firewall/NAT config yet.
Sorry, dont know how.. if you mean the /ip route print detail and /ip address print detail here they are:
0 ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 interface=sfp1
actual-interface=bridge-local
1 address=10.1.3.1/24 network=10.1.3.0 interface=ether2
2 D address=–.–.–.–/29 network=–.–.–.-- interface=ether1-gateway
actual-interface=ether1-gateway
0 ADS dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.xxx
gateway-status=xxx.xxx.xxx.xxx reachable via ether1-gateway distance=1
scope=30 target-scope=10 vrf-interface=ether1-gateway
1 ADC dst-address=10.1.3.0/24 pref-src=10.1.3.1 gateway=bridge-local
gateway-status=bridge-local reachable distance=0 scope=10
2 ADC dst-address=xxx.xxx.xxx.xxx/29 pref-src=xxx.xxx.xxx.xxx
gateway=ether1-gateway gateway-status=ether1-gateway reachable
distance=0 scope=10
3 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge-local
add chain=forward dst-port=8016 out-interface=ether1-gateway protocol=tcp
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=Winbox dst-port=8291 protocol=tcp
add chain=input comment=“default configuration” connection-state=established
add chain=input comment=“default configuration” connection-state=related
add action=drop chain=input comment=“default configuration” in-interface=
ether1-gateway
add chain=forward comment=“default configuration” connection-state=established
add chain=forward comment=“default configuration” connection-state=related
add action=drop chain=forward comment=“default configuration” connection-state=
invalid
add action=dst-nat chain=dstnat dst-port=8016 in-interface=ether1-gateway
protocol=tcp to-addresses=10.1.3.185 to-ports=8016
add chain=srcnat dst-address=10.1.1.0/24 src-address=10.1.3.0/24
add action=masquerade chain=srcnat comment=“default configuration”
the port im trying to forward is the 8016.
Try this
add action=dst-nat chain=dstnat comment=“DVR”
dst-address=X.X.X.X dst-port=8016 protocol=tcp to-addresses=
where X.X.X.X is your public ip
already did that, didn’t work. I was suspecting about any firewall rule blocking something, so I disabled all restricting rules just for test… and didn;t worked either.
is there any way to activate some kind of log that tells me what is blocking those connections?
Delete your first firewall rule.
Change your DST-NAT action to action=netmap instead. Like this,
add action=netmap chain=dstnat dst-port=8016 in-interface=ether1-gateway \
Also, best practice is having your masquerade rule at the top of your NAT rules, and others underneath it.
that didn’t work either…
I feel there may be something fundamentally flawed with your testing method. Are you attempting to test it by connecting to the external IP of your router from within your local LAN?
No sir, I’m trying to telnet from a remote computer outside the network (in my house actually).
If I telnet from inside the internal lan, I have a telnet connection to port 8016 just fine. So the service is working just fine.
The problem is from my house. also… I’ve tried to telnet a known mail server from my house… and I have response… so telnet is not blocked here.
What is the purpose of this line? Are you trying to stop 10.1.3.0/24 traffic from being masqueraded? Since it isn’t going out the gateway interface it wouldn’t be, anyway. Its existence might be stopping traffic from hitting your other rules.
Also, are you using the 192.168.88.0/24 subnet on your network? Your router still has an IP in that range.
Yes, that rule is for the vpn traffic. (We have a vpn between 2 sites).
And the .88 is the default network, i gUess is there just in case. Not really necessary
actually, making the masquerade rule first, broke my VPN traffic.
is there anyway trace that traffic and see what is blocking it?
You can try setting the ‘log’ flag on all your firewall rules and see if anything pops up. Also, clear your counters and watch if any of the NAT rules have their counters incremented when you try to connect.
I’m out of ideas; I’ve tried your config on my lab setup and everything works fine for me.
sorry for my ignorance, but how do I enable that log? and how do I look at it?
You can append “log=yes” to your firewall rule, and optionally “log-prefix=” to apply a prefix to those log entries. “/log print” shows log if you’re using terminal.
