port forwarding issues newbie
Hey Guys,
i just got myself my first mikrotik router a hap ac and have been trying to configure it for my general use but am having a terrible time trying to port forward on the thing
dec/01/2016 12:28:51 by RouterOS 6.36.4
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input dst-port=8700 in-interface=WAN log=yes
protocol=tcp ## using this as a remote into winbox ## working fine
add action=accept chain=input comment=“defconf: accept established,related”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=input comment=“defconf: drop all from WAN”
in-interface=WAN
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade”
out-interface=WAN
add action=dst-nat chain=dst-nat comment=“Game Ports” dst-port=
7777,27015,8888 in-interface=WAN protocol=tcp to-addresses=192.168.1.220
add action=dst-nat chain=dst-nat dst-port=7777,27015,8888 in-interface=WAN
protocol=udp to-addresses=192.168.1.220
add action=dst-nat chain=dst-nat comment=RDP dst-port=3389 in-interface=WAN
log=yes protocol=tcp to-addresses=192.168.1.221 to-ports=3389
add action=dst-nat chain=dst-nat dst-port=3389 in-interface=WAN log=yes
protocol=udp to-addresses=192.168.1.221 to-ports=3389
add action=dst-nat chain=dst-nat in-interface=WAN log=yes protocol=rdp
what am i missing? in my testing stage i have opened up both TCP and UDP ports and for RDP even with as far as setting its own
from what i can tell i have new connections passing through the forward filter if they are dst-nat
as well as my established and related accepted
if i unplug the router and use a soho tp-link router my forwarding all works, so its a firewall issue on the mikrotik?
any advice would be great
Anthony
Are you testing from inside (same LAN) or outside (internet)? If from inside, you want to read this.
