Port Forwarding Issues
Right so I have absolutely no clue where to write or even ask about this because I believe this is a firewall or very ‘light’ connection issue that I must be so blatantly missing.
For the past 9 hours, I have been frantically trying to set up a Minecraft Technic modpack server but haven’t been able to have it work via my external IP address. Despite the fact everything is port forwarded correctly, port checking tools displaying the fact the port 25565 is actually open and having already disabled my windows firewall multiple times as well as adding rules for the ports, Java and any other things that could be restricting it from working. The port isn’t blocked by my ISP so I have no clue what is going on. I can connect to the server via my local network IP and localhost, just not my external IP. I even went as far as to check whether the server connection was actually sending packets to my router, which in fact it is, but it is always displaying “Can’t connect to server” on the multiplayer page of Minecraft. Whenever I try to join, I get this error: “java.net.ConnectException: Connection timed out: no further information:” and after researching it, have found literally nothing of use. At first all my forwarding was done via UPnP but I had no luck, so I switched to doing it manually via WebFig.
Some of the other things that might be helpful:
  • My internet service provider is Telstra Australia
  • My WiFi router is a MikroTik RB951Ui-2HnD
  • I am running Windows 10 Pro 64bit with the latest version of Java’s runtime environment
I am also 110% sure my IP addresses displayed are correct.
I am at a serious loss right now. Please help…
Kind regards.
Hello, by reading your post, it suggests me that you have a NAT issue, the best way to solve that is to know all of the ports wich Minecraft uses, i don’t believe that the only port is TCP/25565? you can check that with any online port-forwarding tool, and also you can enable logs in the NAT rule where you can see all of the packets that are being natted just to know if your NAT rules are working by hiting some packets, once that you have checked everything, perhaps can you upload a screen capture of those results?
