Port Forwarding Issues
Greetings,
I just received my router and have it set up but am having issues with port forwarding. I have the three ports (80,1337,3306) forwarded through the nat in the firewall but when trying to connect from the outside I am getting ‘Connection Refused’ and am not able to figure out what is wrong.
Here is my /ip export:
# may/23/2015 20:22:09 by RouterOS 6.28
# software id = IQWZ-XJG9
add name=dhcp_pool1 ranges=192.168.150.100-192.168.150.254
add address=X.X.180.21/28 comment="Cox WAN IP" interface=ether1 network=x.x.x.16
add address=192.168.150.1/24 comment="LAN IP Subnet" interface=bridge1 network=192.168.150.0
add address-pool=dhcp_pool1 disabled=no interface=bridge1 lease-time=3d name=dhcp1
add address=192.168.150.0/24 dns-server=192.168.150.1 gateway=192.168.150.1
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall address-list
add address=192.168.150.0/24 list=LocalLAN
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" disabled=yes list=bogons
add address=127.0.0.0/16 comment="Loopback [RFC 3330]" disabled=yes list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" disabled=yes list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" disabled=yes list=bogons
add address=198.18.0.0/15 comment="NIDB Testing" disabled=yes list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" disabled=yes list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" disabled=yes list=bogons
add chain=input comment="Accept established connections" connection-state=established
add chain=input comment="Accept related connections" connection-state=related
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add chain=input comment=UDP protocol=udp
add chain=input comment="Allow limited pings" limit=50/5s,2 protocol=icmp
add action=drop chain=input comment="Drop excess pings" protocol=icmp
add chain=input comment="SSH for secure shell" dst-port=22 protocol=tcp
add chain=input comment=Apache dst-port=80 protocol=tcp
add action=log chain=input comment="Log everything else" log-prefix="DROP INPUT"
add action=drop chain=input comment="Drop everything else"
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.150.55 to-ports=80
add action=dst-nat chain=dstnat dst-port=1337 in-interface=ether1 protocol=tcp to-addresses=192.168.150.55 to-ports=1337
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=tcp to-addresses=192.168.150.55 to-ports=3306
add distance=1 gateway=X.X.180.17
/ip service
set www port=9999
Any assistance is appreciated.
Hi JDunsOK,
The config seems to be correct.
Have you tried connecting to apache directly without router? You have to be sure that your ISP do not block those ports.
Regards
