port forwarding issuse with pcc and webproxy
I need help …
I followed link for PCC with web proxy
http://step-technology.blogspot.com/2011/05/load-balance-using-pcc-method-in.html
Now I am facing port forwarding issues
I solved myself through hard search …
just for your info i need to add 2 rule in firewall filter (input and forward) and one NAT rule in NAT firewall…
Now i m working for NAT hairpin…because through internal network still i m unable to access any port forwarding rule
thanks
I have solved NAT haipin problem. After hard search and try i was unable to access but When I upgrade router firmware then i am able to access lan to public ip successfully.
Thank you for pointing me out in the right direction.
The script you linked here and your comments, and comments from Gilson de Carvalho helped me out forwarding a port to a server!
Best regards,
Eduardo Marques
