Good morning everybody,
We are newbies but we already tried every tutorial and read all the possible posts.
We have an l2tp vpn client to server where the server is M1 and the client is M2. We have to connect using the Ethernet a device to M2. Then we have to access this device using a PC connected to M1 using the vpn.
The device’s address is 192.168.11.100 and the ports that uses for communications are 2000-2005 both udp and tcp.
If we connect the PC to M2 the software recognize correctly the device. However, if we connect (using vpn) the PC to M1 the program doesn’t see the device.
We set up many different configurations of nat and firewall rules. I attach the configuration that we have at the moment.
- M1
# mar/04/2021 08:14:01 by RouterOS 6.44.6
# software id = 9TLC-VZSA
# model = RB750r2
# serial number =
add admin-mac=C4:DA:E4:E8:47:62 arp=proxy-arp auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] arp=proxy-arp
set [ find default-name=ether2 ] arp=proxy-arp
set [ find default-name=ether3 ] arp=proxy-arp
set [ find default-name=ether4 ] arp=proxy-arp
set [ find default-name=ether5 ] arp=proxy-arp
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des,des
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des,des,null pfs-group=none
add name=dhcp ranges=192.168.11.10-192.168.11.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add bridge=bridge dns-server=8.8.8.8 local-address=192.168.11.1 name=L2TPprofile remote-address=dhcp
/interface l2tp-server server
set default-profile=L2TPprofile enabled=yes one-session-per-host=yes use-ipsec=yes
add address=192.168.11.1/24 comment=defconf interface=ether2 network=192.168.11.0
add address=130.111.29.7/24 interface=ether1 network=130.192.29.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes servers=130.111.3.24
/ip dns static
add address=192.168.11.1 name=router.lan
/ip firewall address-list
add address=192.168.88.10-192.168.88.254 list="Block dhcp"
add action=accept chain=input port=1701,500,4500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=forward port=2000-2005,1534 protocol=tcp
add action=accept chain=forward port=2000-2005,1534 protocol=udp
add action=drop chain=forward src-address-list="Block dhcp"
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat port=2000-2005,49841,1534 protocol=tcp to-addresses=192.168.11.3 to-ports=2000-2005
add action=dst-nat chain=dstnat port=2000-2005,49841,1534 protocol=udp to-addresses=192.168.11.3 to-ports=2000-2005
add distance=1 gateway=130.111.29.17
/ppp secret
add name=L2TP profile=L2TPprofile service=l2tp
/system clock
set time-zone-name=Europe/Rome
/tool mac-server
/tool mac-server mac-winbox
- M2
# mar/03/2021 18:36:32 by RouterOS 6.47.9
# software id = DP6U-UX08
# model = RB941-2nD
# serial number = D1190CFCBFD5
add admin-mac=48:8F:6E:6E:C0:A3 arp=proxy-arp auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=italy disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-6EC0A7 wireless-protocol=802.11
add name=dhcp ranges=192.168.11.220-192.168.11.254
/ppp profile
add bridge=bridge local-address=192.168.11.3 name=profile1 remote-address=dhcp
/interface l2tp-client
add connect-to=castiglano.it disabled=no keepalive-timeout=disabled name=l2tp-out1 profile=profile1 user=L2TP
add bridge=bridge comment=defconf interface=pwr-line1
add address=192.168.11.3/24 comment=defconf interface=ether4 network=192.168.11.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.11.0/24 comment=defconf gateway=192.168.11.3 netmask=24
/ip dns static
add address=192.168.11.3 comment=defconf name=router.lan
add action=accept chain=forward port=2000-2005 protocol=tcp
add action=accept chain=forward port=2000-2005 protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward connection-nat-state=dstnat in-interface=bridge
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=bridge out-interface-list=WAN
add action=dst-nat chain=dstnat port=2000-2005,49841,1534 protocol=tcp to-addresses=192.168.11.100 to-ports=2000-2005
add action=dst-nat chain=dstnat port=2000-2005,49841,1534 protocol=udp to-addresses=192.168.11.100 to-ports=2000-2005
/ip hotspot ip-binding
add address=192.168.11.100 disabled=yes type=bypassed
add disabled=yes distance=1 gateway=192.168.1.1
add distance=1 dst-address=192.168.11.0/32 gateway=192.168.11.1
/system clock
/tool mac-server
Can someone help us to figure this out?
Thank you in advance,
Nicola Viale
