Port forwarding limitations with ProtonVPN-Wireguard and Docker
I am new to networking, so I hope someone can identify some bad assumptions I'm making. My problem: I want to port-forward seed traffic to port 6881 while still being able to remote access my webservices.
My home network is NATted behind a Proton VPN wireguard tunnel. I want to access the web services of my docker apps via public domain resolving to my ProtonVPN Public IP on the customer-specific port 150.250.0.1:12345 and ultimately be served by my server at 192.168.77.10 on ports 80 or 443.
Traefik proxies this traffic to the correct container based on path prefixes so that /qbittorrentwill return the webgui for my qBitTorrent instance. However, I need to expose port 6881 of qbit's container in order for seeding to work correctly. Thus, Traefik composes as ports: -80:80 -443:443 and the qbittorrent only composes as ports: -6881:6881
150.250.000.1:12345 ----> 10.2.0.0/30:12345--> dstnat --> 192.168.77.10:6881
[ProtonVpnIP:pubport] --> [LocalWG net:pubport] ---^^---> [my server:6881]
This of course breaks webservices as Traefik is listening on ports80, 443. Because I have only one port from the ProtonVPN-Wireguard interface, there is no way to distinguish which traffic should be routed for webservices. Is this a scenario in which a separate local container IP via docker MACvlans or IPVlans could allow me to preserve both webservices AND selectively port forward to my qbit container at 192.168.77.11?
Secondly, how can I create a dstnat that won't simply forward all traffic to my server? How does it know that the seed connection is only for 192.168.77.11? I realize this is a fundamental misunderstanding of how connections are tracked so I appreciate the insight.
I read the documentation for NAT PMP and UPnP but these are simply configuration docs and assume networking knowledge that I don't have (yet!).
arm64 / hAP ax^3 / 7.21.1 (stable)
Can you confirm that proton VPN gives you the ability to remotely connect to you router? If so, I am assuming they provide you with a different port number (than the one for wireguard), and possibly the same endpoint address?
How is it secure, in that any body on the www, could enter in the endpoint address and port number and then get transferred via wireguard to you router........... aka they do not need any exchange of keys?????
