Port Forwarding NAT thru L2TP Tunnel
Hi there, first time posting on this forum.
I’ve been using Mikrotik for awhile & am probably considered intermediate with my skills… by no means a pro.
I have drawn a picture to best explain my situation & will post my configs here.
I am trying to forward port 80 from my public IP, thru the L2TP tunnel, which connects from behind a NAT, to port 80 on a local devices on the 10.19.56.0/24 subnet.
Config of router with the public IP 104.192.158.xx & private subnet 192.168.101.0/24 running L2TP server.
Also, I am able to ping 10.19.56.56 from this router.
 /export hide-sensitive
# jul/25/2020 11:07:01 by RouterOS 6.45.7
# software id = LHVV-3JEB
# model = RB952Ui-5ac2nD
# serial number = 924D0926AFCA
add admin-mac=B8:69:F4:FA:75:CB auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik10 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-FA75CF wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.101.10-192.168.101.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE bridge=bridge local-address=172.0.0.1 on-up="if ([/interface l2tp-\
    server print count-only where user=\$user && !dynamic] = 0) do={\r\
    \nlog info message=\"L2TP Server Binding current user\"\r\
    \n/interface l2tp-server add name=\$user user=\$user\r\
    \n/interface l2tp-server remove [find where name=\$user]\r\
    \n}" remote-address=172.0.0.2
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set enabled=yes keepalive-timeout=60 mrru=1600 one-session-per-host=yes
/interface sstp-server server
set default-profile=default-encryption mrru=1600
add address=192.168.101.1/24 comment=defconf interface=bridge network=\
    192.168.101.0
add address=104.192.158.67/24 interface=ether1 network=104.192.158.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.101.0/24 comment=defconf gateway=192.168.101.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
    established,related,untracked
    "Accept connection from outside to port 80" dst-port=80 in-interface=ether1 \
    log=yes protocol=tcp
    invalid disabled=yes
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=\
    127.0.0.1
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=104.192.158.67 dst-port=80 \
    in-interface=ether1 log=yes protocol=tcp to-addresses=10.19.56.56 to-ports=\
    80
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add distance=1 gateway=104.192.158.1
add distance=1 dst-address=10.19.56.0/24 gateway=<l2tp-remote.vpn>
add distance=1 dst-address=10.22.0.0/24 gateway=<l2tp-remote.vpn>
/ip service
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
ppp secret
add name=remote.vpn profile=default-encryption
/routing ospf network
add area=backbone network=10.19.56.1/32
/system clock
set time-zone-name=America/Chicago
/system routerboard settings
set protected-routerboot=enabled reformat-hold-button=1m
/tool mac-server
/tool mac-server mac-winbox
Config of router behind the ISP router with NAT, gateway IP of 192.168.1.10, private subnet of 10.19.56.0/24, running L2TP client.
I have all of the drop firewall rules disabled temporarily for simplicity.
# jul/25/2020 12:07:36 by RouterOS 6.47
# software id = LIJ2-78ES
# model = RB760iGS
# serial number = AE370B5EBDFD
add admin-mac=C4:AD:34:DA:7B:B3 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=E8:2C:6D:23:70:FC name=ether1-WAN
set [ find default-name=ether2 ] mtu=1596 name=ether2-BH
set [ find default-name=ether3 ] name=ether3-NDB
set [ find default-name=ether5 ] poe-out=off
/interface l2tp-client
add connect-to=104.192.158.67 disabled=no mrru=1600 name=l2tp-out1 user=remote.vpn
/interface vlan
add interface=ether2-BH name=vlan22.cctv vlan-id=22
add interface=ether2-BH name=vlan99_cx-traffic vlan-id=99
add interface=ether2-BH name=vlan660.voip vlan-id=660
add disabled=no interface=bridge lease-time=1d name=dhcp-default
add name=default-dhcp_pool ranges=10.19.56.100/31
add name=dhcp-cctv_pool ranges=10.22.0.100-10.22.0.200
add name=dhcp-voip_pool ranges=10.66.0.2-10.66.0.20
add address-pool=dhcp-cctv_pool disabled=no interface=vlan22.cctv lease-time=1d name=dhcp.cctv
add address-pool=dhcp-voip_pool disabled=no interface=vlan660.voip lease-time=1d name=dhcp.voip
/port
set 0 name=serial0
/ppp profile
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge comment=defconf interface=ether3-NDB
add bridge=bridge interface=vlan99_cx-traffic
set discover-interface-list=all
add comment=defconf interface=ether1-WAN list=WAN
add address=10.19.56.1/24 interface=bridge network=10.19.56.0
add address=10.22.0.1/24 interface=vlan22.cctv network=10.22.0.0
add address=10.66.0.1/24 interface=vlan660.voip network=10.66.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1-WAN
/ip dhcp-server config
set store-leases-disk=1d
add address=10.19.56.0/24 comment=defconf dns-server=1.1.1.3 gateway=10.19.56.1
add address=10.22.0.0/24 dns-server=1.1.1.3 gateway=10.22.0.1
add address=10.66.0.0/24 dns-server=1.1.1.3 gateway=10.66.0.1
set allow-remote-requests=yes servers=1.1.1.3
/ip dns static
add address=192.168.88.1 name=router.lan type=A
add action=accept chain=input comment="Allow Remote Winbox Connection" in-interface=RemoteWinboxVPN
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add distance=1 dst-address=192.168.101.0/24 gateway=l2tp-out1
/ip service
set www port=98
/system clock
/system identity
set name=hEX-CoreRouter
/tool graphing interface
add interface=ether1-WAN
/tool mac-server
When I try accessing the public IP on port 80, it attempts to load but never gives an output on the webpage, from outside the network or inside.
I’ve read lots of guides & threads but have not successfully got anywhere yet.
Any help would be appreciated. Thanks a bunch.
Levi
Problem is that when server sends response to client, router sends it to own default gateway, it doesn’t forward it back via tunnel. There are two ways how to solve it.
Simple one is to add masquerade rule on router with public address, for connections forwarded to server. Router behind NAT will think that all connections came from VPN server and it will route responses there. Downside is that server won’t be able to see real source addresses.
Better solution is to add another default route in different routing table (on router behind NAT) with gateway being L2TP server, mark new incoming connection from tunnel and then mark routing for responses to marked connections, to make them use the other routing table. Server will see original source addresses and router will forward responses correctly to tunnnel.
Hi I have the same problem. What if I select default route option in L2TP settings? Do I need to use the better solution too? Because the default route is already through the L2TP tunnel. Please advise thanks
