Port-forwarding no working
I have a Mikrotik HAP AX lite as a main router on bridged Huawei fiber router. And I need to port-forward port 4368 and 4370. I have tried everything dstnat by myself, copying commands from the internet, even using the QuickSet Port Mapping feature which makes a dstnat rule again the same as I. The closest I was when I tried to also port forward telnet because the device I have also has telnet, and I got to the router’s telnet. There is some traffic on the rules couple of packets but then it’s just fails to connect. I tried everything even disabling the firewall rules. Can you help in anyway?
Here is the config:
add admin-mac=48:A9:8A:83:F0:2A auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid=disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.55.10-192.168.55.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
    path-cost=10
set enabled=yes udp-timeout=10s
/interface detect-internet
set wan-interface-list=all
/interface wireguard peers
add allowed-address=192.168.0.0/24,10.10.0.0/24,192.168.55.0/24 \
    endpoint-address=62.162.168.141 endpoint-port=13231 interface=wireguard1 \
add address=192.168.55.1/24 comment=defconf interface=bridge network=\
    192.168.55.0
add address=10.10.0.148 interface=wireguard1 network=10.10.0.148
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.55.0/24 comment=defconf dns-server=192.168.55.1 gateway=\
    192.168.55.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.55.1 comment=defconf name=router.lan
    "Allow Forwarding Traffic from WireGuard Interface" in-interface=\
    wireguard1
    established,related,untracked
    "Allow traffic from 192.168.55.0/24 to 192.168.0.0/24" dst-address=\
    192.168.0.0/24 src-address=192.168.55.0/24
    "Allow traffic from 192.168.0.0/24 to 192.168.55.0/24" dst-address=\
    192.168.55.0/24 src-address=192.168.0.0/24
    "Allow Return Traffic from LAN to WireGuard" dst-address=192.168.0.0/24 \
add action=accept chain=input comment="Allow WireGuard traffic" dst-port=\
    13231 protocol=udp
add action=accept chain=input comment="Allow WireGuard DNS" dst-port=53 \
    in-interface=wireguard1 protocol=udp
add action=accept chain=forward connection-state=established,related
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=log chain=input log-prefix="DROP: "
add action=masquerade chain=srcnat comment=\
    "Masquerade traffic going out of WAN" out-interface-list=WAN
add action=dst-nat chain=dstnat comment=zkteco dst-port=4368 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.55.220 to-ports=\
    4368
add action=dst-nat chain=dstnat comment="zkteco 4370" dst-port=4370 \
    in-interface-list=WAN protocol=udp to-addresses=192.168.55.220 to-ports=\
    4370
add action=dst-nat chain=dstnat comment="4368 udp" dst-port=4368 \
    4368
add action=dst-nat chain=dstnat comment=telnet dst-port=23 in-interface-list=\
    WAN protocol=tcp to-addresses=192.168.55.220 to-ports=23
add action=dst-nat chain=dstnat comment="4370 tcp" dst-port=4370 \
    4370
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=wireguard1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set interfaces=wireguard1
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    connection-state=invalid
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/
/system logging
add topics=wireguard
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-dst-ip-address=192.168.0.0/24 filter-interface=all
Reading your firewall rules was making my head explode. Do yourself (and the rest of us) a favor and move your firewall rules around so that all the rules in each chain are together. In other words, all the Input chain, then all the forward chain, etc. Does not make any difference to the router, but makes it FAR easier for us poor humans to read.
Also (and this is my opinion - shared with a lot of others as well), change your rule strategy so that you have rules that specifically allow what you want to all, and then the last rule in each chain is a drop everything. You are running a combination of allow and drop rules intermixed which makes it more confusing, and far more prone to errors. In some situations you have to do some strange stuff, but the allow what you want and drop everything at the end works well for most situations.
With all that said, your problem description says that you want to forward ports 4367 and 4370, but your NAT rules are ports 4368 and 4370. Also port 4368 you are NATting UDP and TCP, but 4370 only UDP. Don’t know if either of those are part of your problem.
Thanks for the improvement insights, I will do it for sure. There’s an error in the text I want 4368 and 4370 ports open. Anyway I saw that 4368 is only TCP, but that is not the problem. I can’t access any of the ports on TCP nor UDP.
