Port forwarding - not accessible from web
Hello. I need to connect to my computer via ssh through Mikrotik router having a static IP address. Router config:
[admin@MikroTik] /ip firewall filter> print
 0   chain=forward action=accept connection-state=established
 1   chain=forward action=accept connection-state=related
 2   chain=forward action=accept protocol=igmp
 3   chain=input action=accept protocol=icmp
 4   chain=input action=accept connection-state=established
 5   chain=input action=accept connection-state=related
 6   chain=input action=accept protocol=udp dst-address=224.0.0.0/4 in-interface=ether1-gateway
 7   chain=forward action=accept protocol=udp dst-address=224.0.0.0/4 in-interface=ether1-gateway out-interface=wlan1
 8   chain=input action=accept protocol=udp dst-port=1001
 9   chain=forward action=accept protocol=udp dst-port=5500
[admin@MikroTik] /ip firewall nat> print
 0   chain=srcnat action=masquerade out-interface=ether1-gateway
 1   chain=srcnat action=masquerade out-interface=bridge-local
 2   chain=dstnat action=dst-nat to-addresses=192.168.1.18 to-ports=22
     protocol=tcp dst-address-type=local dst-port=23
That’s how I can connect from local router’s web:
ssh user@192.168.1.18 -p 22 //directly
ssh user@192.168.1.1 -p 23 //router port forwarding
ssh user@109.173.41.*** -p 23 //router's static address
But now I try to connect from some other web with the last command - and it fails with timeout exception. What’s the problem? Please tell I have to provide any more information about router configuration. Thank you!
Read this: http://forum.mikrotik.com/t/port-forwarding-problem/93224/16
and this: https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Forward_all_traffic_to_internal_host
Choosing port 2200 instead of 23 helped. Thank you for your answer
You haven’t disabled internal router servicee (telnet) occupying port 23.
That was the problem.
