Hello
I have the same situation as in this topic http://forum.mikrotik.com/t/port-forwarding-not-working-at-all-no-ports-open-on-port-checkers/138439/1
I try to go through the steps but had no success ![]()
I have RB952Ui-5ac2nD r2 OS 7.1
I recently reset my router config. and setup only WiFi, Lan, DNS and NAT.
I want to host Nextcloud through port 443, I am already set up everything on my Raspberry in Docker and everything works smoothly on the internal network.
By the way, I am using Pi-Hole.
Iâm not sure if firewall rules have meaning by position, so I attached a screenshot.
# dec/15/2021 23:27:42 by RouterOS 7.1
# software id = LJCS-UUPJ
# model = RB952Ui-5ac2nD
# serial number = CC3E0B2B77B5
add admin-mac=C4:AD:34:98:27:C6 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=lithuania disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MATRIX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=lithuania disabled=no distance=indoors \
frequency=auto installation=indoor mode=ap-bridge ssid=MATRIX \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.127.10-192.168.127.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.127.1/24 comment=defconf interface=bridge network=\
192.168.127.0
/ip dhcp-client
add address=192.168.127.0/24 comment=defconf dns-server=192.168.127.3 \
gateway=192.168.127.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.127.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat dst-address=192.168.127.0/24 src-address=\
192.168.127.0/24
add action=dst-nat chain=dstnat comment=Nextcloud dst-port=443 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.127.2
add action=dst-nat chain=dstnat dst-address=!192.168.127.1 dst-address-type=\
local dst-port=443 protocol=tcp to-addresses=192.168.127.2
local dst-port=443 protocol=udp to-addresses=192.168.127.2
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Vilnius
/tool mac-server
/tool mac-server mac-winbox
