Sorry if I have missed something essential, I only recently started using mikrotik routers.
I was trying to setup port forwarding and got it to work, but only when using it outside of my network, when I try to access it in my own network it doesn’t work.
I also noticed that the web panel can be accessed on both local and external addresses, but not outside the network, can that be related?
[admin@MikroTik] > /ip firewall nat print
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no
log-prefix="" ipsec-policy=out,none
1 ;;; http
chain=dstnat action=dst-nat to-addresses=192.168.0.127 to-ports=3000
protocol=tcp dst-address=(my external ip) in-interface-list=WAN dst-port=80
log=no log-prefix=""
edit:
Forgot to add the hairpin nat rule:
2 chain=srcnat action=masquerade protocol=tcp src-address=192.168.0.0/24
dst-address=192.168.0.127 out-interface=bridge log=no log-prefix=""
anav
November 1, 2024, 8:01pm
2
Ensure port forwarding rule is more flexible, than the default rule..
Remove the current default forward chain rule that covers incoming from WAN and dstnat with a block rule, and
Replace with
add chain=forward action=accept comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add chain=forward action=accept comment=“port forwarding” connection-nat-state=dstnat
add chain=forward action=drop comment=“drop all else”
Rule has too many components (extra noise)
1 ;;; http
log=no log-prefix= “”
Should be
1 ;;; http
protocol=tcp dst-address=(my external ip) dst-port=80 log=no log-prefix=“”
Thank you, that worked well it seems like. just in case here is the firewall rules, if there is a problem here.
[admin@MikroTik] > ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
3 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
4 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
5 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
6 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
7 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
8 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes
connection-state=established,related log=no log-prefix=""
9 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
10 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
chain=forward action=drop connection-state=new connection-nat-state=!dstnat
in-interface-list=WAN log=no log-prefix=""
12 X ;;; internet traffic
chain=forward action=accept in-interface-list=LAN out-interface-list=WAN
13 X ;;; port forwarding
chain=forward action=accept connection-nat-state=dstnat log=no log-prefix=""
14 X ;;; drop all else
chain=forward action=drop log=no log-prefix=""
anav
November 2, 2024, 9:12pm
4
I only comment on complete configs… Glad its working for you now.
Oh, here are also the NAT rules for completion:
[admin@MikroTik] > ip firewall nat print
0 chain=srcnat action=masquerade protocol=tcp src-address=192.168.0.0/24
1 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix=""
2 ;;; http
protocol=tcp dst-address=(external ip) dst-port=80 log=no log-prefix=""
anav
November 2, 2024, 9:38pm
6
Change the first NAT rule, the hairpin nat rule, to this.
add chain=srcnat action=masquerade src-address=192.168.0.0/24 dst-address=192.168.0.0/24
