I need to open samba share from internet for a couple of minutes, but usual port forwarding rule doesn’t work.
Can you help me?
And I know about samba security issues, so firstly I tried with “src-address=my_current_address”, but it didn’t work.
So trying most simple rule, doesn’t work too. Forwarding all 137,138, 139 and 445 ports.
I’m not sure action=netmap accepts a single IP address as to-addresses value, you should use action=dst-nat instead. And put back the src-address=your.current.ip.address, as it was not the reason why it did not work. Plus you don’t need to use to-ports if you don’t need to change the original dst-port value.
Samba also uses 445 for file sharing it is after all microsoft-ds so same port you’d open on windows, 139 you don’t need across the internet they’ll get to you by public ip address or dns name no need for Netbios name resolution, use a dst-nat rule to forward 445 to your samba host and may god help you, security wise i mean. make sure you have the latest build of samba pkg for you distro.
Again all rules are needed to determine which one is causing the problem something is forwarding your publicip:445 to an internal host before it gets to the samba dst-nat rule,try in nat move the samba dst-nat to the begginng of the list am sure it’ll work or your samba is blocking connections.
*netmap - creates a static 1:1 mapping of one set of IP addresses to another one. Often used to distribute public IP addresses to hosts on private networks
Not familiar with this, but clearly if your nat chain is full of netmaps you’re mapping 1:1 so you can’t use the same public ip of any netmap rules for samba since the port 445 is already mapped to another internal ip.
I may be wrong, but I believe action=netmap ignores ports even if you provide dst-port as rule parameter. So if a netmap rule is before a dst-nat one and matches, the dst-nat one never sees the packet.
No, I have several netmap rules with different ports. I can change any netmap action to dst-nat action and it works. And I tried to place samba rules on top.
and then move these two rules as high in the chain as possible (i.e. make them the very first static rules in that chain).
If they count packets when you attempt the SMB connection, the issue is in your firewall; if they don’t, your ISP is blocking the port whose rule does not count.
if you can, post the netmap rules and remove public ips from them, not sure if hide-sensitive will do that. Maybe you missed something or misunderstood how something works and someone else can spot it, can’t troubleshoot with limited information.
netmap is a direct 1:1 mapping public to private there is no port choosing here that is in dst-nat.
You’re not getting any traffic on the dst-nat rule for samba so the problem is in mangle since that is the packet flow.
i wouldn’t discard this, it’s very possible if you are just been handed /24 bit address blocks and ISP knows you’re corporate and might be unpatched.
