Hi All,
I am new to Mikrotik and was wondering if someone could assist me with getting Port Forwarding to work as it should.
I have seen a couple of videos and with a trial and error I am still not able to get this to work.
Description:
I would like to access my servers from outside my network on specific ports from anywhere using the Mikrotik Cloud Address and not the public address.
Issues:
- I am not able to connect from outside the network.
- Log error captured: (dstnat: in:pppoe-out1 out:(unknown 0), connection-state:new proto TCP (SYN), 105.245.102.247:43502->102.217.111.245:55111, len 64)
- Portable device: (Connection timed out)
Notes:
- I have disabled the firewall on the OS level and still the same issue.
Exported Firewall Filter and NAT:
/ip firewall address-list
add address=(Hidden Info) list=PublicDNS
add address=0.0.0.0/8 comment=“Self-Identification [RFC 3330]” list=Bogons
add address=10.0.0.0/8 comment=“Private[RFC 1918] - CLASS A # Check if you need
this subnet before enable it” list=Bogons
add address=127.0.0.0/8 comment=“Loopback [RFC 3330]” list=Bogons
add address=169.254.0.0/16 comment=“Link Local [RFC 3330]” list=Bogons
add address=172.16.0.0/12 comment=“Private[RFC 1918] - CLASS B # Check if you ne
ed this subnet before enable it” list=Bogons
add address=192.0.2.0/24 comment=“Reserved - IANA - TestNet1” list=Bogons
add address=192.88.99.0/24 comment=“6to4 Relay Anycast [RFC 3068]” list=Bogons
add address=198.18.0.0/15 comment=“NIDB Testing” list=Bogons
add address=198.51.100.0/24 comment=“Reserved - IANA - TestNet2” list=Bogons
add address=203.0.113.0/24 comment=“Reserved - IANA - TestNet3” list=Bogons
add address=224.0.0.0/4 comment=
“MC, Class D, IANA # Check if you need this subnet before enable it” list=
Bogons
add address=192.168.5.0/24 list=LAN
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=drop chain=forward comment=“Drop to bogon list” dst-address-list=
Bogons
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
/ip firewall mangle
add action=mark-connection chain=forward comment=
“Mark incoming connections from the WAN port” in-interface=ether1
new-connection-mark=Incoming_From_WAN passthrough=yes
add action=mark-packet chain=forward comment=
“Mark all incoming packets from the WAN port” connection-mark=
Incoming_From_WAN new-packet-mark=Incoming_Packets_From_WAN passthrough=yes
add action=mark-connection chain=prerouting comment=
“Mark upload connections to WAN port” in-interface=Lan_Bridge
new-connection-mark=Upload_Connections_to_WAN passthrough=yes
add action=mark-packet chain=prerouting comment=
“Mark upload packets to WAN port” connection-mark=Upload_Connections_to_WAN
new-packet-mark=Upload_Packets_To_WAN passthrough=yes
“Mark HTTP/HTTPS traffic (Download)” new-packet-mark=
“HTTP/HTTPS Traffic (Download)” packet-mark=Incoming_Packets_From_WAN
passthrough=no port=80,443 protocol=tcp
add action=mark-packet chain=forward comment=“Mark HTTP/HTTPS traffic (Upload)”
new-packet-mark=“HTTP/HTTPS Traffic (Upload)” packet-mark=
Upload_Packets_To_WAN passthrough=no port=80,443 protocol=tcp
add action=mark-packet chain=forward comment=“Mark all other download packets”
new-packet-mark=All_Other_Download_Packets packet-mark=
Incoming_Packets_From_WAN passthrough=no
add action=mark-packet chain=forward comment=“Mark all other upload packets”
new-packet-mark=All_Other_Upload_Packets packet-mark=
add action=dst-nat chain=dstnat comment=NAT_To_Qbittorrent dst-address-list=
PublicDNS dst-port=55111 log=yes protocol=tcp to-addresses=192.168.5.39
to-ports=8080
Your help would be appreciated.
